hi guys i have a r33 s1 skyline with 145,000ks on the clock no leaks/problems at all,the car is great on fuel $75 to fill and i get 550ks out of a take easy and it doesnt smell fuelly only a bit wen its cold drives good at cruising speed in any gear but if u put ur foot down its like the car starts to go then u can feel it holding back not julting but just a constant hold back in boost???it seems to start around 3k revs and goes right though the rev range i have checked all vacuum hoses and fitted all hose new clamps it has a r34 side mount intercooler and the standard boost controller disconnected and a turbo smart boost tee fitted running 7psi boost.it has a 3.5" super cat exhaust with highflow cat.i have had the car for 4 months and the car was fine wen i bought it.to try and fix the problem i have also changed the afm,replaced the fuel pump with a standard 2nd hand fuel pump,iridium spark plugs gapped at 0.8mm r33 gtr coil packs.with these things changed there has been no improvement.if i hold my foot flat to the floor it just starts goin then the turbo keeps boosting but it just take ages for it to climb up the rev range and if i keep my foot down and punch it through the gears wen u back off the gas at anytime it backfires and caries on and sometimes at idle it it runs realy rough then if u give it a rev it sometimes fixes it but other times it does it for a while even after driving it for a bit .any suggestions on wat it could be or a ruff guess on a price for someone to have a look.im located at wyong on the central coast so if u have any suggestioins of mechanics/tuners that could help me out that would be great,cheers
https://www.sau.com.au/forums/topic/382159-help-with-r33-s1-skyline-boost-loss/
I don't think he means boost in psi so much as just not wanting to pull. ie, low power.
This could be anything at all. Bad fuel pump (which can include things like a poor earth, not just the pump itself), bad injector or injector connector, collapsed cat, blocked fuel filter, weak coil (although they usually make life a bit more miserable than your situation sounds), etc etc etc.
hi guys
I have an r33 s1 skyline with 145,000ks on the clock, no leaks/problems at all.
The car is great on fuel, $75 to fill and i get 550ks out of a tank easy and it doesn't smell fuelly, only a bit when its cold.
Drives good at cruising speed in any gear, but if u put ur foot down its like the car starts to go then u can feel it holding back, not julting, but just a constant hold back in boost???
It seems to start around 3k revs and goes right through the rev range, i have checked all vacuum hoses and fitted all new hose clamps, it has an r34 side mount intercooler, the standard boost controller disconnected and a turbo smart boost tee fitted running 7psi boost.
it has a 3.5" super cat exhaust with highflow cat. I have had the car for 4 months and the car was fine when i bought it. To try and fix the problem i have also changed the afm, replaced the fuel pump with a standard 2nd hand fuel pump, iridium spark plugs gapped at 0.8mm, r33 gtr coil packs.
With these things changed there has been no improvement. If i hold my foot flat to the floor it just starts going then the turbo keeps boosting but it just take ages for it to climb up the rev range and if i keep my foot down and punch it through the gears, when u back off the gas at anytime it backfires and carries on and sometimes at idle it runs really rough, then if u give it a rev, it sometimes fixes it but other times it does it for a while even after driving it for a bit .
Any suggestions on what it could be or a rough guess on a price for someone to have a look.
Im located at wyong on the central coast, so if u have any suggestioins of mechanics/tuners that could help me out that would be great
cheers
Sorry mate, im no help with your problem, but for some reason i felt compelled to modify your post.
FYI - big blocks of text like you have written, make me click the back button.
Have a quick glance at yours then a quick glance at the one above -- which one would you rather read ? cheers.gif
thanks cobbadan im not much for punctuation.
its like gtsboy said every goes up as normal boost guage etc but it just has no pull.
it started doing it a week after i got it and i dont thrash it i just use it as my daily but after it started doing it i cleaned the pod filter and afm i used proper senser cleaner on the afm and it did improve cold starting.i also changed the fuel filter and fuel pump,spark plugs with iridiums and replaced the coil packs with r33 gtr coil packs.its been serviced regularly and drives great wen u drive it like a nanna.i was also thinking the problem may be injectors or fuel presure regulator?is there a way to test these?
the computer is still stock,i havent checked base timing and not really sure how to on these.i havent had it dynoed cause i didnt know if they could do uch with a stock ecu??
This^
And...you spent a whole lot of money fixing stuff that wasn't broken. Type in r and r into the search feature and see what you come up with.
wheres the part where i spent a whole lot of money??
it was due for a service so i put iridium plugs in it
i put new coil packs in cause i got them off a wreak that a mate had for free
hose clamps i got from work for free
fuel pump came off the same wreck for free
so all in all i havent spent much money at all which is the plan obviously so thats why i thought that i would ask for some advise and hopefully get me out of trouble without spending a whole lot of cash.
Edited by RB25 SKYLINE
thanks stevoss i rang dvs jez and am goin to see him om on saturday to hopefully sort out this issue,hes the first person ive rang that was actually happy to chat for 5mins so fingers crossed my car will be back to normal again without spending to much coin.thanks for ya help and feedback guys cheers
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
