Hey guys tried doing a search and I am trying to find my boost restrictor on my r33 Gtr?
There is no restrictor in the pipe with the yellow band.. Is there another one? The car won't boost over 9psi.. There is a bleed valve on the car.. This fitted on the drivers side near the intake.. But the boost controller wires still connected..
Pictures or links or help much appricated..
Steve
https://www.sau.com.au/forums/topic/382163-gtr-restrictor/
run your boost solenoid on the turbo side, u can cap off the lines that connect to the stock boost solenoid
Search for the rb26 vacuum diagram which shows how to hook your boost controller up properly
Any pictures of how this is done.. Could I just put my boost controller over at the turbo side?
https://www.sau.com.au/forums/topic/382163-gtr-restrictor/#findComment-6096481
http://i.imgur.com/B4stl.jpg
thats a picture of how i had mine setup, basically i installed a nipple on the bottom of the 'twin turbo' pipe and got the pressure source from there
You put a T piece in there going to the solenoid but what did you do with the 2 standard pipes that go to the inlet manifold? Also where's the other vacuum pipe going to?
https://www.sau.com.au/forums/topic/382163-gtr-restrictor/#findComment-6096532
Right I found the rear boost restrictor under the inlet manifold at the back marked with a yellow band, removed and my car is no different, still runs just under 10psi.. What else could it be?
Had a look for the yellow band mark on the front coming off the boost controller but I think my pipes have been replaced.. I know it's had a engine before..
https://www.sau.com.au/forums/topic/382163-gtr-restrictor/#findComment-6097002
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
