Hi guys
I've got some mostly S15 stuff to sell. Everything came off a JDM Manual turbo car.
Stuff is in good condition unless otherwise stated.
Pics can be seen here.
https://picasaweb.go...feat=directlink
Im located in Baulkham Hills 2153, Sydney NSW
All prices are FIRM.
Intresting Stuff
1. S15 Front Seats. A little tiny bit of fading on drivers side, but no tears or rips. Comes with rails as well. $300
2. S15 Rear seats. Good condition, no rips or tears, but have been sitting in the shed for a while, so need a wash. $50
3. 4 x S15 480cc injectors. $200
4. S15 Greedy Thermostat block adaptor thing. Has Dash 10 fittings for an oil cooler. $100
5. Just Jap Recaro copy seat. Drivers side. Perfect condition, has never been used. Its red. $100
6. D1 Spec Just Jap oil catch can. I bought it about 3 years ago, but I've never used it. Its still in its original box. $30
7. Honda Integra DC2R carbon fiber rear lip. It can be made to fit S15 front bumper with some heatgun goodness and some bending, but it sits really low, so i dont want to install it. $100
8. S15 Sandwitch plate for oil filter. Has 2 sensor fittings. $20
9. S15 Exedy Heavy Duty clutch. Comes with stock dual mass flywheel, and all bolts. Its got heaps of meat left. Its been barely used. $150
10. S15 Exedy Brass button clutch with heavy-as-hell pressure plate and stock dual mass flywheel. The clutch is worn, and it all has been sitting around for about 1 year, so theres surface rust everywhere. $50
11. Earls Oil filter relocation block. It has Dash 10 fittings, and the hread suits a 3/4" oil filter. It has no sensor ports. $20
S15 Boring Stuff
1. S15 stock rear camber arms - $30
2. S15 stock rear toe arms - $30
3. S15 stock tie rods - $50
4. S15 stock tie rod ends - $50
5. S15 stock castor rods. I think the bushings are gone. $20
6. S15 stock Xenon light modules. Come with the bulbs as well. $40
7. S15 stock BOV. Comes with the mounting bracket as well.
8. S15 rear hubs. One of the hubs is missing 3 bolt studs. Nissan sell these for about $7 new. $150
9. S15 tailshafts. The longer one has the thread a bit screwed cause i smashed it with a hammer when i took it out of the hub. Its not that bad, but it does need a bit of fixing. $50
10. S15 Engine and gearbox mounts. Have around 120,000kms on them, so a bit worn, but not broken. $20 EACH
11. S15 Front shock mounts. The bushings are pretty screwed. $20
12.S15 Washer bottle - $20
13. S15 Intake cam gear. $20
14. S15 RHS only front lower control arm. $15
15. S15 RHS only TEIN castor rod. $50
I have a bent/broken LHS castor rod and TEIN control arm as well, but theyre really bent. You can have them for free if you want.
16. S15 Fuel pump. $50
17. S15 gearbox shifter rubber boot thing. $10
18. S15 front LHS seatbelt
19. S15 interior trim panels. $20 EACH. Look at the pics to see which ones there are.
Skyline Stuff
1. R33 Rear bumper bar. It has been sanded down back to plastic about 75%. $20
2. Sparco (I think) drivers side seat rail for Skyline. Its bottom mount, similar to the bride ones. It came off a sparco seat. I dont know what else will fit on it. $50
3. R34 GT Non-turbo wheels. I think specs are 16x6.5" with +40 offset. All tyres are shagged. $150
4. ECR33 S2 Front grille. Silver. All clips are there. $20
Edited by Goosy
Oops, some mistakes in the first post
S15 BOV should be $50
And I dont have the intake cam gear (aka the VCT thing). Its actually the camshaft itself.
Hey mate you don't happen to have a stock JDM S15 ECU by any chance do you? Shoot me a PM
Edited by ryu1605
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
