Mongoose M80 Problem - Only One Side Of The Indicators Work And Only 1 Door Unlocks
Hi Every1,
I have a R34 with a Mongoose M80 alarm installed in it.
When unlocking it, the central locking doesnt work properly (passenger side door does not unlock) and only half of the indicators work.
I've been doing some research. Could this be caused by a blown fuse in the alarm itself? If so, where is the fuse? Is it actually in the mongoose unit?
And could both problems (indicators and door not unlocking) both be caused by the fuse? Or when the fuse is normally blown, does it only impact the indicators? (If this is the case, im assuming I also have a stuffed actuator).
Will be giving this a go tomorrow, but always appreciate advice from the pro's.
Thanx heaps in advance for the direction.
sounds like someone did not know what they were doing myself. it is a fuse and if you can find the unit to will be very apparent.
Thanks Chris, found a busted fuse for the alarm and replaced. Has fixed the indicators but the passenger side door still does not automatically unlock.
Will buy a new lock actuator and fit. Unless there is a fuse in one of the stock fuseboxes for it (From memory there isnt?)
If u know off the top of your head?
Hey mate, fixed this today - issue was caused by a fuse missing in the interior fuse box! The 10A bat fuse.
Have attached a pic incase it helps any1 else 1 day.
Regarding my previous post, was going to replace the actuator as I thought it had ceased. Great that this was not the case.
Thanks heaps anyway though!
Edited by iwanta34gtr
