hey guys my car is for sale, its a white r33 gts-t with a 34 front on it.
Owned the car for around 3 years now (i think), and i literally never get to drive it due to working long hours and having a work van.. so I'm moving on.
mods are as follows
rb25det (there is 190xxx on the dash, i was assured this engine had 75xxx on it when i bought it and it was fitted - iv put less than 2000kms on it since owning new engine)
vipec ecu with boost control setup to 10 and 18psi
K&N pod filter
hks 2540 turbo
turbosmart bov
Hybrid FMIC
full turbo back exhaust system
Tomei FPR
nismo 740 cc injectors
walbro fuel pump
splitfire coilpacks
excedy Heavy duty clutch
new calsonic radiator
air con condensor is also brand new
18"wheels with new rubber on them
alpine headunit
6x9s in parcel shelf
tweeters installed on a pillers
autometer boost gauge
dry cell battery in the boot
front and rear sway bars
it has a viper alarm system that has just stopped working, never got it fixed just used key :D
there is more stuff done to the car, i just cant remember at the moment
the 34 conversion was done by tony at perfection bodyworks. the conversion is pretty much perfect, everything lines up.
carlos at millenium motorsport tuned the car and it made 330rwhp on 18psi. lots of fun to drive
like i said the car just sits there i never drive it any more, its going back to carlos to get serviced in a week to get serviced
the paint has some blemishes mainly on the rear bar it is cracking a little bit and on the side skirts everywhere else is good.
the only known issues the car has is the starter motor is on its way out, it doesnt disengage right away after the car starts (throw out bearing i think)
asking price is $14 999
contact number 0421 467 355 car is located in morningside brisbane
sorry this add is probably really bad i'v never made one before so feel free to ask any more questions
cheers
Edited by existence
https://www.sau.com.au/forums/topic/382235-fs-96-s2-r334-gts-t/
  • 3 weeks later...
  • 3 weeks later...
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
