Go tto give it to the Russians. Cant see anyone doing this along the Motorways here
(cant get it to work?? so link below)
http://www.youtube.c...player_embedded
http://www.youtube.com/watch?v=K-eDRFOv_GA
Edited by R31Nismoid
https://www.sau.com.au/forums/topic/382276-2-tt-gallardos-vs-ams-alpha-12-gtr/
Spanner in the works.
From another forum. Still fast none the less.
Just to clarify that is not a true ALPHA 12 car. That car has a mildly built 3.8L engine with stock heads, cams springs etc. We actually tuned that car when we were in Moscow and had to cap it at 850whp due to the factory heads causing valve float. I don't know where that 1100whp is coming from but its certainly not correct.
Eric
ahh, i see the problem with the lambo.
the problem is the two big ones he insisted he need by that night caused too much danger to manifold and made him top out at a hundred and sixty. now he and the mad scientist have to rip apart the block and replace the piston rings he fried.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
