hi everone my r33 gtst decided it dont wana start i dont drive it very much so started it up to give the battery some volts n while ideling in the shed it just shut off n now winds over but wont fire had noticed the last time i drove it that the revs where dropping a bit at idel. been going threw all the usual suspects n all that was left was the cas n the ecu manually tested the cas n athe coils click n the injectors are fine. i spoke to the nissan dealler here n they told me that even though the cas worked when i manually tested it that it could stilll be the problem is this the case or is he havin me on? any help would be greatly appreciated thanks
https://www.sau.com.au/forums/topic/382281-cas-problem/
yup CAS can still be stuffed, mine would spark and have injectors clicking but was the problem, replaced and it started first time
What CAS does ur car have, all metal early model?
Thats really good to know Fingers crossed that my prob!!
https://www.sau.com.au/forums/topic/382281-cas-problem/#findComment-6098487
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
