yep if you dig, martin posted some dyno overlays of 09 vs 11 with midpipe and tune and both were pretty much the same
the 09 owner would have gotten more bang for buck out of those 2 mods natch
Edited by domino_z
  • Replies 55
Leaps and bounds? Doubt it. AFAIK the differences 2008 to present are minor in terms of hardware. Some intake, ECU and suspension geometry etc. In terms of outright/straightline performance i am sure a tuned 2009 is as quick as a new one today. The only big factor in terms of 0-100 performance is probably software on the launch (which version you have) however you can get that sorted if you care. If you are comparing say 2009/2010 vs 2012 model (re the saving) i would say it depends on what you want to do with the car? Personally being interested in having a quick road-going track-capable car i would acquire the older car and spend the savings on mods. I dare say a new car with $50k on mods vs an older car with $50k on mods would yield the exact same outcome (except your wallet). Plus I would feel less 'bad' about trashing an older vs newer car, if you know what i mean.
You hit the nail on the head with that post. Although some people just want the latest & (not always) greatest, if they have the means then more power to them & not all car enthusiasts are modifiers.
thanks for the response as this has been on my mind for quite some time - much appreciated.
now its time to relay this back to my mate
i'll be buying an early model in this case :nyaanyaa:
is this you? incredibly quick!!!
Yep that was me last round of the NSW sprints last year, there was just 1/10th separating Marek and I (in championship points) leading into last session of the day, last round, with only a single point in the championship. I managed to pull a rabbit out of my ar$e and grab another 0.5s out of our times for a 60.8s lap (60.7s on the GPS) to win the championship outright, type and class. i still don't know how i managed that really!
2 digits @ wakefield - im gobsmacked!
what is your PB @ the creek, 1:38?
also - what power are you running awkw when racing?
yes we were running 1:38's - but we've done a lot more laps at wakefield. by rights we should probably be running 36's at EC or theeabouts, with new rubber. just need bigger balls for T1. We would be running about 385awkw in E85 tune for these times. Not bad, i drive to car to work every day, flick a switch for the e85 map, put some tyres on, and smash a 60.x at WP. I just don't think any other road going car (in this sort of easygoing trim/comfort) could match it.
that is awesome - the r35 is definitely going to be next car without a doubt.
i know its slightly off topic but you have my intrigued with your gtr because i like it sooo much :) what engine mods are u running to make 385awkw on e85 (surely boost level is not factory)?
The mods for that power are exhaust, Willall e85 tune, upgraded injectors and fuel pumps. Boost is up to about 16lbs i think.
Did anyone else get the fold out brochure from Nissan about the new GTR and asking if you want to spend $10-20k on suspension and brake parts on your 09-10 model to bring it up to 2012 spec?
Can you elaborate on this more? Maybe pictures?
http://www.insideline.com/nissan/gt-r/2013/2013-nissan-gt-r-first-drive.html
Nissan is now claiming zero to 60 mph in 2.8 seconds (down from the 3.1 seconds we achieved in the 2012 GT-R), although the 193-mph top speed is unchanged and is defined by the car's gearing. These are the only figures officially released by Nissan, but Mizuno admitted he's hoping that independent testing will show a standing quarter-mile in 10.6 or 10.7 seconds. The fuel consumption is also marginally improved if you're into that sort of thing.
[/Quote]
1/4 mile in around 10.6 seconds. Damn!!
Did they mention what the suspension changes were?
shocks, springs, arms? I'd like to see how they manage to alter the pick up points!
$9500 gets:
390mm front brake rotor left and right
Front brake caliper and tube left and right
Front brake hose left and right
Front brake pads left and right
Rear brake cross spring left and right
VDC actuator
$19800 gets:
Shock absorbers front and rear
Springs front and rear
Front upper link left and right (special gold colour and increasing negative camber range)
Front transverse link bush left and right
VDC actuator
my brochure for my 2010 says $4990 for the brake upgrade and $13xxx for the brakes + suspension
nissan must have changed the calipers 2009 to 2010
the extra 10mm on the 2011 discs comes from wider hats and then a different bracket bw the caliper and upright to push the caliper out 5mm, otherwise us 2010 owners wouldnt be able to re-use our existing calipers + pads in this kit
so the extra braking performance 2010 vs 2011 isnt really from increased surface area of the disc as one would initially think, but rather from the increased cooling effect by taking a longer cycle for the disc to travel one full rotation under the pad
when im due for front discs, ill just order the new caliper bracket and larger discs as 2011 spare part like i did upgrading my M3 brakes to the larger CSL discs
Edited by domino_z
Actually Domino your reasoning there is not sound.
A larger diameter means a bigger circumference, but all points on a theoretical line from centre tangentially to the circumference complete 1 revolution in the same time.
The distance to travel may be greater for a point further out from the centre, but the surface speed of that point is greater also.
The increase in braking effectiveness would come from the increase in "leverage" gained by moving the pad further out from the centre.
Pad material may have changed also.
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
