  • Replies 55
This sounds like one of those brain teasers
So turboadam are you saying a single point on a larger circle wil still take the same time to travel a full rotation than a smaller circle?
Common sense would assume the larger circle takes longer to rotate
Edited by domino_z
Your rim has a smaller circumference to your tyre, but of course they both take the same time to complete one rotation otherwise your tyre would be spinning on the rim. The cap in the center of your rim also takes the same time for one rotation. The speed is the variable as the circumference increases.
EDIT: I have not received anything offering suspension updates for an MY11 to this new asymmetric design.
Edited by OzStriker
my brochure for my 2010 says $4990 for the brake upgrade and $13xxx for the brakes + suspension
nissan must have changed the calipers 2009 to 2010
the extra 10mm on the 2011 discs comes from wider hats and then a different bracket bw the caliper and upright to push the caliper out 5mm, otherwise us 2010 owners wouldnt be able to re-use our existing calipers + pads in this kit
so the extra braking performance 2010 vs 2011 isnt really from increased surface area of the disc as one would initially think, but rather from the increased cooling effect by taking a longer cycle for the disc to travel one full rotation under the pad
when im due for front discs, ill just order the new caliper bracket and larger discs as 2011 spare part like i did upgrading my M3 brakes to the larger CSL discs
I'm confused now as to what the differences are between the 09 and 10 brakes for the $5K difference in the conversion..... And if the main change between the 10 and 11 brakes is just a caliper spacer then what do you change on the 09 to go to 11?. Calipers, pads and spacer? Can't imagine that if they're charging $5K for just the spacer that a caliper and pad change will add "only" another $5K. At the drive day Mizuno told me that a spacer was all that was required but I don't recall that I had mentioned it was from an 09 to an 11. He would probably have assumed a 10 to an 11. What's interesting is that when I bought my 09 I was told that a complete brake pad and rotor change would cost $20K for front and rear brakes, it appears now that if you wanted to go down the OEM path it will cost you no extra to convert to the MY11 brakes than what it would have cost to just re-rotor and pad your 09 back to original brakes!
And the increased cooling is primarily due to the increased surface area and (thermal) mass of the rotor. There is increased braking force for the same amount of brake pressure because of extra leverage due to the centre of friction being further away from the rotating axis but this does not improve temperature performance because the same energy is being absorbed by the brakes anyway you cut it. You are actually correct in a way about the "time" aspect even though you didn't state it clearly because if the pad length is the same yet the rotor is increased in circumference the size of the angular arc the pad covers is actually reduced therefore any point on the swept part of rotor surface actually spends a greater percentage of the rotation period time exposed to the air and less time under the pad undergoing friction and warming up thus improving cooling efficiency. It's effectively a change in the duty cycle. It's not hard to visualise if you just exaggerate things up to bike tyre size etc for it to make more sense.
Edited by fungoolie
09 upgrade includes new calipers
10 upgrade does not
i did a similar upgrade on my m3 when i was due for new front discs. i went with the larger csl front discs and they came with a different bracket bw the upright and caliper - caliper and pad are identical
i doubt the change in r35 caliper is a mounting issue. id assume its some internal change they made to the caliper itself, and in "upgrading" nissan figure you're better off with the newer improved caliper - remember there is a visual difference bw the 09 and 10 caliper in the lettering on the face
Edited by domino_z
doubtful
the rear seat delete means it'd have to be classified as a 2 seater - which means Nissan Aus would need to ADR it again ?
the bigger issue though is the Aus rrp - Nissan Aus in the 2011 model are now bringing in the base model Japanese GTR (all black seats and grey roof lining) to keep the currency exchange price rises as low as possible for the end consumer
this track pack would be pushing mid 2s easy
Edited by domino_z
1323507657[/url]' post='6147318']
http://www.motorauth...-launch-planned
do you think we'll get it?
Some people are working very hard to make it happen, there is a good chance we will see it in Australia!
  • 3 weeks later...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
