Hey guys,
First post on SAU, not a skyline owner, putting an RB25 into my VL commodore this week. Gives it that little more "rep" Than a SOHC 30.
Basically i have a VLC with an RB25, the vehicle is running and drives well, just has some, err.... Cosmetic damage. Currently stripping it down for the install on friday,
How in the fuaaaark is the 4 bolts on the underside of the inlet plenum removed? I litterally having nothing that will get to it. Because of the bogan spec wiring it has unfortunately i cannot get my hands in under the plenum runners to stick a socket and extension up. Any info on this noob matter would be muchly appreciated!
Thanks guys,
Jacob
Edited by DoriCom
https://www.sau.com.au/forums/topic/382310-rb25det-inlet-manifold-removal/
Yeah man cheers, Going to have a beer and call it a day before I crack the shits, So ill have a drunken sleep and attack it tommorow with a more docile "hangover" mood lol Im an apprentice mechanic so i've got a Kingchrome top and bottom filled with cheap goods, So im thinking get under it with a 1000ft extension and come through the runners. Doesn't help that it fits very nicely with bogan stereotype and is on SSL springs, and with my.... build.... Im going to be dryhumping the shit out the cooler i think! Plus the wiring is giving me hell!! So much bodgeynessness!!
take off the left cam cover as it will give you a bit more room and a straighter angle, give it a crack from the top with ratchet ring spanner. If you have got one with the end the pivots on a hinge will make your life easier. Stil not easy butt i eventually got mine off. hope it helps mate
yeah what he said and will help if you got a ratchet spanner.Putting on is worse because you have to start it on the thread lol fun times.
Thanks guys will do, just left it on and ripped the motor. Had the intention to just throw it straight in, but seeing as it was in another VL, Im certain it would feeling similar to a slapped ass, so Im going to freshen it all up, unfortunately no mods until a bit later next year, but definately contemplating a filter relocation kit! What a whore to remove!
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
