set of 2"/52mm gauges (brand new, never used) set x 5
white set of 2"/52mm gauges (brand new, never used)52mm TYPE R performance gauge set0-100psi oil pressure meterboost 0-30 in.hg to 0-20 psi meteroil temp 2"/52mm gauge meterwater temp 2"/52mm gauge metervolt measure 2"52mm gauge meterall 5 gauges brand new in boxall 5 gauges come with accessories etcall 5 gauges are electricalmounting bracket, english instructionshigh quality products
2"/52mm "DRIFT" boost gauge brand new never used
$50
WRECKING HR31
ALL PICTURES ARE AT THIS LINK>>> <a rel="nofollow" href="http://s149.photobucket.com/albums/s44/luker_1987/HR31%20PARTS/" target="_blank">http://s149.photobucket.com/albums/s44/luk...7/HR31%20PARTS/</a>
Hr31 drive shafts / axles inner & otters $400
R31 hot plates good condition $80
52mm alloy radiator suits rb $80
Ba/au twin thermo fans $55 + 12" inch thermo fan $30 + twin thermo 10" inch "from memory?" $30
Hr31 complete rear brake set up $70
Hr31 rear struts & lowered springs $50
Hr31 doors x 4 >>NOW PARTING<< electric windows, switches, glass, door handles (chrome) door cards sold
Hr31 guards (driver & passenger sides) $80 each x 2 sets (gun metal grey or silver) one silver drivers doors sold
Hr31 rear bumper trim says "skyline" on it $50
Hr31 or R32 side mount intercooler $50
Hr31 seat belt covers (driver & passenger) $45 & rear quarter glass interior covers $50
Hr31 door rubbers (seal the doors) $50
Hr31 rear quarter glass surrounds says "skyline" on them (not the sticker type) $80
Hr31 complete seat belts (front & rear) $50
Hr31 floor carpet full (front & rear) $100
Hr31 roof lining $40
Hr31 dash $50
Hr31 blinker/turn signal lever & wiper levers, headlight/high beam levers $40 each
Hr31 dash buttons (random bunch, let me know what you need)
Hr31 dash clock & other dash parts available
CAN USE AUST POST OR COURIER MOST ITEMS (AT YOUR COST) I'M LOCATED IN COOMERA (GOLD COAST) PICK UP FROM THERE CHEERS LUKE
  • Replies 87
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
