im currently trying to get my R31/RB25 turbo registered in NSW. took it for an emissions test today and completely failed
using all stock parts for the emissions test bar a 3" exhaust, turbo is at 7 psi.
high flow CAT(i think this may be causing alot of the problem it may be screwed)
any advice on wtf went wrong would be great
here are the test results.
Edited by r31rb25help
https://www.sau.com.au/forums/topic/382353-rb25-failed-nsw-emissions-test/
Yep.
And why do u need an emmisions test with a standard ecu? Have the rules changed? Try another engineer
apparently i need the test because the engine im using is imported.
im thinking i should just replace the entire exhaust system on it for something with passing this damn test in mind
and i dont know what to to about it dumping about 2x the fuel its allowed to into the exhaust at the moment,
dug up my old stock exhaust and put 2 3way CATs on it after some advice from a mechanic, looks like horrid and runs horrid but it will apparently pass.
he also recommended i dont run my intercooler at all just a "straight" pipe.
He's trolling for sure. Ask him if he will pay for the new engine after yours goes bang from detonation?
why is it dumping 2x fuel it should be into the exhaust? if it is overfueling heaps then theres no way it will pass have you got bigger injectors in it or something?
