hey all, i have for sale a greddy copy plenum, cast alluminium, never used, comes with all fittings and hoses.
also have a q45 tb that comes with it. i think i have the tps sensor with it aswell. q45 tb has had the water idle springs removed, so its just a bolt on now, all works with the r33, but with minor mods, it works with the r34's neo engine.
included is also a new manifold gasket. im only wanting to sell it as a set.
$500 ono
reason for selling i have lost my job so now most of my car parts have to be sold :(
pickup is in hurstville, sydney but can post at buyers expense
https://www.sau.com.au/forums/topic/382396-r33-greddy-copy-plenum-q45-tb/
$450 anyone??
i bought the manifold from usa thats supposedly made in USA, dont think there would be much diff to a china one. for all of this i paid close to $600 and none of this has ever been used.
trying not to sell TB separately as of yet
to fit it to a neo engine, (thats what i bought it for) you need to make a small adaptor plate for the aac, and buy different injector rings. injector rings are 50c each and to get a aac plate made, i got quoted 10 bucks.
there was a thread in the stagea section that explained the walk through in detail. i dont remember what it was called though.
