Hey guys,
Just been roaming and stumbled upon these things call Air intake supercharger boosters. Does anyone know if they actually work or do anything? any feedback would be appreciated.
This link explains what they are meant to do. http://www.performancechiptuning.com/Air+Intake+Supercharger+Booster/2/
Another gizmo I found was a Pivot Mega Raizin battery stabalizer chip. Any word on these and how they perform?
Here is a link to one of these http://www.nengun.com/pivot/mega-raizin
Cheers,
Dallas
https://www.sau.com.au/forums/topic/382403-extra-power-methods/
oh dear. You are going to get flamed to the shithouse for posting this lol.
But just to clarify, I bought 4. Two for the intake, one before the the electric supercharger, and one after the turbo.
I also installed one before the cat converter, and after the cat converter.
helped get the air in and out efficiently.
I'm now thinking of buying a 5th one and installing it just before my ATMO BOV.
essentially, no. the amount of airflow these things can contribute is F-A, meaning they do.... F-A.
And because they are bullshit and also made from such substance they have been well known to fail and break apart. And seeing as they are upstream of the intake, guess where the bits end up? and guess what they do? they should be renamed a 'rebuild catalyst'.
N think about it, if something like this could actually make a difference the big manufacturers would be doing it.
Thread closed. Believe it or not, but since SAU started more than 7 years ago, this topic has been discussed before.
Please use the search function in future. It may be found here:
http://www.skylinesaustralia.com/forums/index.php?app=core&module=search&search_in=forums
While we understand that it can be frustrating to have your thread closed - Please consider that other members may feel it to be disrespectful and selfish of you to post a simple question, without using the search feature to review the wealth of information provided by said members over the years.
If you still feel that this action is unjust, then please PM me and we can discuss it further.
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
    • I don't think he's got it on a gauge and on the ECU. I think he's got it on the gauge and on the HPTuners DAq thingo. Remember, we're talking about oil temp here, not something that the ECU is actually interested in for its own sake.
