Deca Officials
RCHOO
 Share
Its really my fault, I never submitted the leave request. I thought I did, I submitted like five all at once for exams and a wedding, but apparently not for DECA. Even though I had spoken to my manager several times about having this weekend off, but when I actually saw my hours it was too late to change/replace them. No one wants to work a Saturday.
On the plus side I always spend a stupid amount of money at DECA which can now be put towards the 180 fund.
We are a bit late on this but Kat and I will be there.
Kats turn to drive something and I will volunteer so put me wherever - I will need some guidance on what I need to do though as never done one of these.
Am I able to reg as a driver as well and have one or two blasts here or there? No crashes I promise :P
Cheers.
I will find you a spot. its not brain surgery so you will be fine. Be there for the breifing and we will word you up.
As for having a blast here and there that would be a no.
Unless you enter and have your CAMS or AASA licence have your car ready and pay all fees.
See you guys up there
Cheers.
Awesome!
Yep sorry I meant if we are both entered as drivers, but we only have the one car. We have our CAMS licences etc and doing the forms / payment now.
Yes Paul you can both enter and drive the car. The team will space your numbers so once the first driver has their turn you should be at the start of the pack again for the second driver.
The days are pretty cruisey so you wont have any issues.
 Share
    • You've given zero info about your setup. Step 1: make sure all the standard equipment are working as they should. If they're not, go investigate why. Step 2: Make sure all your wiring is done properly. Know which RB20 you have, most likely "silvertop" a.k.a R32/A31 anything after 1989. Step 3: make sure your ECU is tuned properly. Standard will barely run in this situation.
    • Depending on your use case, prop valve will almost always be a better choice.
    • I think... in the US, Silvermax is the equivalent of BC Racing, i.e. cheap Taiwanese built suspension that gets turned for "local" conditions. Back in the day in Australia, you could get MCA street for about $1300 and they were awesome. Don't know about now... In saying that, my real world TEIN experience: I got some street basis z for my old Liberty (BR9), and they were awesome ($800-odd delivered from demon-tweeks in the UK). so Don't discount TEIN
    • yeah my RedBull X2010 on Grand Valley is only good enough for bronze... I can't hit silver arrgh.
    • 100% this. Long ago, I had a guy from the R31 club who set my BNR32 up (adjustable arms all round). He did an awesome job, was an after-work kinda thing where I had to bring a slab of beer. My car never drove better, and I stupidly got a random tyre shop to check the toe angles when I changed tyres, and they ruined the alignment. tl:dr- it takes a lot of skill to set up your car lowered from factory properly, and is worth paying the $200+ it takes.
