  • Replies 41
whereabouts u from
im in melb
only problem is Denton33 pm me earlier and said he was going to come down and get my brake pads and fc commander if it works on his newer model power fc
otherwise u can give me a call on 0423 351 754
but basically if ur outside of melb u might have to wait to c if this sale falls threw or he doesnt call me and i could cod it on monday
Hey Michael,
we're in luck.  Couch search proved successful, I can buy at $350.
Where do we go from here?
Adrian
hand controller is still for sale
however $350 is the lowest i will sell it for
otherwise i rather just give it to my mechanics for a christmas present
If you've still got it, I'll take the hand controller for $300.
Adrian
I was a confirmed buyer at $350 a month ago, but I didn't hear from you after you said Denton33 was coming to look at it. Do you want to sell it or not? As they say, a bird in the hand...
$300, cash sale, someone will pick it up in Melbourne for me. It doesn't get any easier. I guess it didn't work out with Denton33, but it will with me.
Adrian
sozman its hard man with the hand controller
i had a guy come on sat with $350 ready to buy it
however when we plugged it in the apexi logo came up and thats about all that happen
so it was wrong model
so if i send it ova to u and it wrong model wat then....
Ahh, I see. I believe my FC is the late model one too, and that perhaps I need the X001, not the N001. The workshop that sold my FC originally can't be sure which one it is, I don't bloody know, so best not rush into anything I guess.
Initially I was prepared to take a bit of a punt if you dropped the price, but for $350 I'd prefer to make absolutely certain I'm buying the right thing.
Will research more and get back to you,
Adrian
I see... I think I need the later X001, not the N001. I can't get a definite answer from the workshop that originally supplied the FC. Best not to rush I guess. Initially I was prepared to take a punt if the price dropped, but for $350 I'd prefer to know I'm buying the right controller.
Will research and get back to you.
Adrian
Hey Michael, i was speaking to u out the front of CREATD one time and you were telling me bout a place where i can buy some parts. It was some website, can u remember?
few more things for sale
apexi rsm with g sensor as new $350
Alpine CDA 7893R CD/MP3 Player (full specs can be found at alpine.com.au)
$550
Nismo Radiator chrome cap $60
Nismo Oil Cap Chrome $140
Nisom Petrol Cap Chrome $60
  • 3 weeks later...
Number Plates (INCTRL) VIC Plates
one slimline and one standard size
offers over $1000
Apexi Power FC commander Model No. 415-N001 for r33 gtst
as new condition with manual etc
$350
Apexi 60mm gauge holders * 2 $30each
Apexi AVC-R, RSM, AFC etc holder $30
Original R33 side indicators $20
Original R33 injecotors * 6 $80
Race Brakes brake pads for r33 fronts as new only used for 200k's $70
Alpine 7893R 60*4 cd/mp3 player as in pic $550 as new
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
