Say what?
Fiberglass replacement part/panel is what FRP stands for
lol ---> FRP meaning! :)
Most kit cars & some manufacturers cars are made from frp or carbon, kevlar and a few other alternate materials. So im sure it would be possible to get them engineered if need be.
I had frp panels all over one of my cars for several years, bonnet, boot, 1/4s, aprons etc, never had a problem with it. Probably no-one ever noticed, being painted?!
The supplier of Fibreglass bonnets with ADR approval is Blits Bodykits in QLD. I am unsure if there approval carries over to other states or not as I am unsure on how the whole process works.
The website is http://www.blitsbodykits.com.au/
problem is when you change from steel to FRP or even aluminium (GTR guards etc) it changes the "crash worthyness" of the car, hence making it un-roadworthy.
It sucks because front guards are not structural, but in the even of a prang fibreglass/carbon splinters will spray everywhere, even more so if you hit a pedestrian.
If you have the budget to crash test all your panels (like blits did) i.e crash your car into a wall a few times then you can produce adr approved stuff.
I'd be dubious if an engineer will touch stuff like that, but it may be possible given enough cash.
In saying that I had a Carbon bonnet on the R33 for years an never got picked up on it.
completely different rules apply for kit cars to mass production cars. same with hot rods when run on limited rego
Say what?
And no not legal in either state
wikipedia says FRP stands for fibreglass reinforced plastic . . . BUT in this context means something else
BRISBANE , i thought so = NO RULES
Just a quick quote from the blits website.
"BLITS is the first Australian company in Australia to manufacture street legal fibreglass bonnets, that made for federal regulation transport approval Australia wide".
So it would appear they are approved for use in all states and not just QLD.
called RTA no problem with fiberglass guards .... then called an engeineer here no problem went over the pits with mine 30mm fiberglass front and rear guards passed no worries words stated to me by the inspector " i have no problem with these as they dont fall under any ADR restrictions" ? he also had no problem with my bonnet pins?
anyway not sure in melbourne but call and ask if you can or not?
2.7.1 Strength and Thickness
The thickness, of non-intrusion panels, with gel coat removed, must be at least 3.5mm.
Bonnets and guards are examples of non-intrusion panels
The strength and thickness of structural components such as floorpans and bodies that
incorporate seatbelt anchorages, door hinges and latches etc., must be certified by a signatory.
The fixings for replacement fibreglass panels should have the same positions and must have at
least the same strength as the fixings used for the original panels. A combination of steel and
neoprene washers of a minimum 20mm diameter should be used with all fixings.
Seat and seatbelt anchorages, door hinges and latches must only be affixed to fibreglass
panels, floorpans or bodies that have been reinforced to take the loads such components are
capable of generating both in normal use and in a crash.
4.3.2 Fibreglass and Other Composite Replacement Panels
Original bolt-on metal bonnets and mudguards for pre 1971 (ADR 10) vehicles may be replaced
with fibreglass or other composite panels that comply with sub-section 2.7, providing the
modification does not increase the rigidity of the front structure of the vehicle and the
collapsibility of the steering column on ADR 10 vehicle is not compromised.
The catches and/or the design of the replacement bonnet must prevent it from being propelled
through the windscreen into the cabin area in the event of a frontal collision.
http://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/pdf/NCOP6_Section_LH_Body_and_Chassis_01Jan2011_v3.pdf
http://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/vsb_ncop.aspx
Links kindly supplied by Zebra
