  • Replies 81
Posted Images
It was pretty painful watching last year while my car was in the build so I'm getting fired up for the next one.
Who else is in?
U should no the answer to that wouldn't miss it for the world and miss out on frying some tyres.
:thumbsup: :thumbsup: :thumbsup: :thumbsup:
  • 1 month later...
VERY keen to go to Powercruise 2012. NOT keen to get defected on my way in. I have never been to this event, and its been many many years since I have entered a car in Summernats.
How likely is it that the police will be there on the first day it opens? You know... if i get there early. Its a long way to tow my 260RS Stagea and Mooney Mooney on the F3 freeway scares me unsure.gif
Whats so crazy about this stagea...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
