hi guys,
thinking of going down then harness road, and just wanted to pick some brains on which harness to get?
are all harnesses created equal or is it another 'get what you pay for' situation? And can they be installed without hacking up too much or making any major adjustments to anything?
Had a look at rhdjapan at the Nismo harness. $$$$ :(
https://www.sau.com.au/forums/topic/382441-what-harness-are-you-using/
no, they are not all the same (well maybe in seat belting ability, but not in usability).
Look for 5 or 6 point, never 4 (4 doesn't deal with the biggest issue, submarining)
Always get the wider one (3" from memory), the wider they are, the more comfortable on long runs.
Make sure they have a rotary buckle, much easier to use day to day and in a rush (eg car on fire)
If you can, check the adjusters. Good quality belts/adjusters slide smoothly, cheapies dont and get caught up.
I am with Duncan on most points. However with R34 seats you are really limited to running a 4 point harness. You can buy a 4 or 6 point but the reality is you cant use the crotch strap on a std R34 seat. So unless you have plans of going to a race seat then I am not convinced you need to incur the price premium over a 4 point harness as you are limited by seats.
I personally think you are wasting your money going to Nismo harness, especially when you can have a top quality schroth, Willans, Sparco/Sabelt etc harness. If I could justify the money I think the Schroth Profi II-Enduro is about the best out there. My budget is only $800 for two harnesses as I am shopping for a set for my new seats.
Having a daily R34, your best bet is a full harness bar that bolts behind the back seat, renders your back seat useless, but a harness bar or half cage are IMO a miniumum if you want to safely run a harness in a Skyline.
So from there its jsut a matter of getting a harness that you like, try to get good quality alloy buckles and quick release straps.
Ye 4 point is the only option with factory seats, it's not really a problem. Fine in my car.
Will suit what you want to do Chinny, basically the same as what i do etc events wise.
I have a Sabelt, and not really impressed (previous owner), it's a mega PIA to use although that said it's a few years old now so a bit worn. I'll upgrade to something much more user friendly next year.
I use one, through the headrest single hole.
It's a tad uncomfy if you don't settle the straps correctly as almost overlap. Previous owner had it like that and regularly did WRX days and the CAMS scrutineers there never said anything. I've since been and it's never been questioned either.
I will probably get a better seat next year though, not a R34 seat as they are just overpriced for what you get.
What's with everyone wanting Japanese harness and seats......
The mountings are probably more important than the harness in an accident. I see alot of them eye bolted to the floor pan in all sorts of weird places.
Even in an accident there is a good chance that the factory rear belt locations will move drastically In relation to the front seat ( those points were never designed to be a restraint for the front seats)
The belts will either tighten or loosen neither of which is acceptable.
A decent harness bar mounted between the two rear c pillars just above the parcel shelf is the most ideal way to go about it without a cage.
I don't think the japs have an off the shelf one of those but if you source some decent 38x2.6mm CDS steel any exhaust shop should be able to make something semi reasonable for you.
If possible ask them to use the factory 7/16ths seat belt locations on the pillars and have some neat spacers made so there is no need to cut the pillar trim.
And being a CAMS "approved" material you shouldn't ever run into any scruiteneering issues.
I'm with Roy. I don't use a harness in my car. Its hard to get a 4pt harness mounted such that the lap belt stays over your hips when the shoulder straps are tightened. Using the facory lap-sash mouning points pretty much assures the 4pt lap belt will ride up over you abdomen, which can cause internal injuries in an accident. Safer to use the standard lap sashbelt than a poorly mounted 4pt - which most I've seen at track days are.
or if upside down... a normal press-button buckle won't release until you get all your weight off it.
Edited by hrd-hr30
And if you are going to install rails for a race seat don't use the Bride Low Max or whatever they are called. Use the other Bride rails which seem to be better for race seats
ie
Don't use this one. I do and they are farking garbage. I have twice welded gussets and whilst it gets better , the saying "you cant chrome dog shit" comes to mind
You can see where the side mount goes that it is essentially one big cantilever and easily distorts with some load on it
These are the ones that are generally better from what I have been told. Though I have wiped them all and going back to custom...
I recall a thread in the last 6 months on the same subject, and it had some useful responses as to which Harnesses are most user friendly. Might be worth a search :thumbsup:
Personally, I've found Sabelt and Willans to have the best sliders.
Thats why I love the Schroth. Was in and out of a friends rally car and they are so easy to adjust....no kicking and screamign trying to tighten the lower belts because a different person has jumped in the car
  • 2 years later...
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
