Hi all, was looking into ECU choices. And I was hoping you guys might have some input for me. Was looking at getting an 'Apexi Power FC PRO', but thinking of some other brands like Wolf, Microtech and even Motec :pirate: etc. might be another option. :rofl:
I have an RB26DETT running stock turbo's after rebuild 20,000 km's ago. :ermm: In which im in process of purchasing some Garrett 2860R -7 turbo's.:merli: I was going to install a new fuel system and run 800cc 'Sard' injectors. Only issue is that I obviously need a ECU to run this new setup. :wacko:
Other thoughts I had on ECU choice include: :teehee:
To go with 'MAP' or keep the 'MAF'S'? <----- Keep going through AFM's, since boosting to 12psi. Can only clean them so many times (CO2 cleaner $$$). Think I really need to install that PVC catch can if im going to run more boost.
Do some Aftermarket ECU brands have better capabilities? For ACC, engine managment, eg, Electronics Sensors (in GTR) AC Control Sensors, Altesa System Sensors, Torque Sensors, ABS, etc?
Another option I was thinking, was to buy a mapped ECU (Mines ECU), and add piggy back the ECU, for other control's, and sensors (outputs on aftermarket ECU though).
I can justify paying around the $1000 on an ECU, Unless you can change my thoughts. Would like to hear some peoples ideas! Thanks in advance again guys. :miner:
https://www.sau.com.au/forums/topic/382455-r32-rb26-ecu-choice/
For -7s you don't really need to upgrade injectors. You could get away with stock ones and a tiny rail pressure bump, also stock AFM's - meaning you only have a $900 cost of a PFC (new)
Good luck tracking down a PFC Pro, they don't come up very often and fetch closer to $1200-$1300 second hand.
Whatever your choice - talk to your tuner. If $1000 is your budget, then PFC is the only choice realistically.
And for the love of god stay away from "MINES" tuned ECU's and what not, they are just paperweights.
Choose a tuner, ask what ECU or ECUs they prefer, buy that ECU.
Cheapest option is Nistune: www.nistune.com
In the end the tune (and tuner) is more important than ECU selection.
Don't bother with a mapped ECU (especially Mine's), unless you want to destroy your engine, although we are quite happy to provide contact details of engine builders to rebuild your engine.
Quote
"For -7s you don't really need to upgrade injectors. You could get away with stock ones and a tiny rail pressure bump, also stock AFM's - meaning you only have a $900 cost of a PFC (new)
Whatever your choice - talk to your tuner. If $1000 is your budget, then PFC is the only choice realistically."
Thanks, good to know. Can hold off on injectors till I do CAM's. What fuel rail you recommend? As im peaking out stock one. with 12 PSI.
I'll check the 'Nistune' ones out. Been down that pathway once before, if a re-call. It cost me over $10k last time. Thanks.
Cams are a bad decision for turbos that small IMO.
Also fuel rail - stock. There is no way you are maxing a stock one, they are fine for over 400rwkw
Must of miss heard mechanic. Must of just be talking about the standard injectors. I already got fuel pressure then by the sound of it, so im back to injector size.:domokun: so what boost you thinking of running with standard injectors, I wanted like 17 PSI.
http://www.tomei-p.c...5_ae_Letter.pdf
17PSI to 22PSI out of these turbo's.
Not a question of boost - question of airflow & power.
Stock injectors will do 300rwkw give/take. A minor rail pressure bump will get you to 320rwkw which is all -7s are going to make.
Don't really need to drop $900 on injectors.
:rofl2: What types of ECU do you other R32 GTR owner's use? Are you happy with you're choice of ECU? :rofl2:
I use a Power FC but its limitations are a little worrying. You may aswell use Nistune with that setup.
The Power FC has had its day anyway.
Edited by djr81
Honestly I would spend the mo st and get a haltech or vipec, something to consider with a power fc is that it costs about 900, but you want more power later on then you have to spend 600-900 getting new afm.....
For the same price straight up you can get a much better ecu that uses a decent map sensor, has 32x32 mapping, much better features and upgradable firmware
use the stock fuel rail, put on your turbos and save for an ecu that you and the tuner are comfortable with just remember that if you spend good money now you can save later haltech vipec etc run map so no need for afms later have better tuneablity and will make the car run smooth like stock :) spend it now then its will do you for the life of the cars upgrades if you plan to go futher with different turbos cams etc.
i personally am going to run the haltech platnium pro as the tuner knows it and its functions tick my boxes
Best of luck
He is Victorian - not having working MAF's is a EPA death sentence.
Fine for you interstate guys, but down here ECU choice isn't just driven by tuner. It's also driven by stealth and trying to be "as stock as possible".
for my 296kw @ wheels with -7 turbos, im running a nistune ecu, nismo 600cc injectors for piece of mind and mainly because i didnt want to push the stock ones near 100% duty cycle, and a Sard intank fuel pump running 14volts. plenty of headroom and safety in the juice department
running 19psi.
So the vipec fits into the factory case.... and you can retain the intake with airbox and afm. They are just not functional. Mr popo will never know the difference. My engine bay looks stock as with afm in the piping and plugged in, I run a power fc djetro (probably changing to the haltech soon but engine bay will still look the same with using map sensor).
Sorry dude but you don't know what you are talking about with regards to what happens down here and it's not as simple as you make it out.
The EPA will unplug the AFM, it's a 30sec check to tell them if you have an aftermarket ECU or not. They are not stupid down here unfortunately.
If the AFM unplug doesn't work, then they will look closer at things like injectors (colour of tops), and even open up the ECU case. I've had them open up the case on my ECU as the consult port wasn't working, which they can also plug into.
daaaaamn. all that effort they will go to down there scares me on so many levels.
meanwhile, the real criminals in the world are up to all sorts. Good work filth.
i couldnt survive with these rules....
obviously they cant see the fact that a car tuned correctly can still be passable for emissions gas testing.
and older cars without mods, may fail due to wear.
what a shame.....
