R33vit
Excelent times mate for your set up, so whats you trick with your 60' times?? You must be running slicks??
ThanX Robo
Im using a set of very well worn Bridgestone Potenza's RE540s 225/50/16's... there street slicks. I think I will be looking at a set of Nitto's before long..
Ben thanx for the update.. I will be out to get a scanner today so I can send you my best time slip... You know the one I showed you at WSID on Saturday...
Adding NOS on it's own will not yeild you a 12 second pass... At the end of the day Adrian is a very good racer and no one can take that from him...
I may not be abled to do it again, I dont know, but I believe I will... I see guys go to the track with the same amount of power and cant peddle it for sh1t... It comes down to practice and been abled to understand what the fcuk is going on when you launch your whale...
Adrian jump in anytime here mate
I haven't got a Skyline, but rather it's little brother - an Australian delivered S15/200SX
60' 1.912
330' 5.392
660' 8.210
mph 87.53
1000' 10.670
ET 12.741
MPH 109.01
running 195rwkw, 80% worn Bridgestone Potenza RE540S (street tyre) at 20psi tyre pressure, 2001 S15 SR20, standard turbo, manual bleed valve at 15psi boost and full street trim (including spare, sub-box, tools etc.).
Okay I will :D
I have been practicing and learning more and more about my car and my abilities over the last 12 to 18 months.
A BRIEF LOOK BACK:
- When I first took this car to the drags (E.C.Raceway strip), it went 14.1 @ 107mph.
- Then I turned the boost up and went two tenths slower. (Wheelspin).
- When I went back again (the bug had bitten), I was elated to find that I had broken into the 13's. 13.9 @ 103mph from memory with a 2.2 60' .
- This was the eye opener. I had gone as fast as 107mph previously but hadn't run a 13 till this.
- A better launch saw the ET's drop at a great rate. Most people (me included) begin by thinking that your ET automatically gets better with more power.
- From here the focus shifted to getting off the line better and with this came much bigger grins :D
- Fast forward to 2 months ago and my car went 13.0 @ 108mph. No more power than before, same tune, no more boost than before, same tyres as before, same driver as before but with a 60' time of 1.9 sec flat.
As you can see, it's a far cry from 18 months ago and 14.3 seconds. The mph has hardly changed (the best indicator of power at the drags), but the driver is a whole lot more practiced and has had some helpful advice from friends. I get to the track every chance I can and I'm constantly trying something different.
If I could offer one bit of advice that meant something to everyone it would be this:
-------- Get REALLY good tyres and save your 'power-up' money for when you're maximising the power you already have. ---------
Adrian
Okay I will :D
A BRIEF LOOK BACK:
Adrian
ThanQ
Couldn't of said it better my self...
I have hardly improved my speed from the first time out at the Wizzard from 13.9 to a 12.9. I have however learnt a little about launching and this is where it all is.. When I get better at the launch I will get better ET's
I could how ever throw more horse power at it and get faster times but this is not as rewarding to me as learning to get the maxamin outta the available traction I have...
Im still learning and it goes on forever :headbang:
All very good advice Adrian. Now I just need to learn how to launch like you and Sam do!
I think my biggest problem to date has been the fact that every time I've gone back to the strip it's been with new upgrades to the car.
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
