hey guys got my welder on Saturday and im already in love
the misses is having a very hard time getting me out of the garage
iv done a fair bit of scratch start tig before but a proper tig is so much better
this is what i have done so far
Made this for a 180sx
this is a 180sx intake pipe
it seals good but eh im not that happy with it :(
and this is a quick r33 intake i made up last night
slowly getting better
hmm what should i attempt tonight??
Edited by Abe2
https://www.sau.com.au/forums/topic/382472-abes-tig-work/
  • Replies 100
Posted Images
The best thing to do is just keep welding; practice makes perfect.:thumbsup:
I reckon pipe welding is the most difficult thing to do neatly, so just keep at it, you're not contaminating your welds, which is good. Are you purging?
Depending on the finish you like, it might be worth your while to get some pickling paste for cleaning.
I'm not into the polished finish, so pickled, then brown 3M pad gives a nice brushed finish; but to each, his own.
You'll get smoother and neater; the prettiness will come. Good on you for being game enough to show pictures, good luck.
Edited by Daleo
https://www.sau.com.au/forums/topic/382472-abes-tig-work/#findComment-6102877
thanks guys
and yeah iv heard about pickling paste i reckon i should get some
sounds like a easy way to clean up some quick welds
and yes more practice is best on the large small pipe i purged
cheers guys ill get more pics up soon :)
https://www.sau.com.au/forums/topic/382472-abes-tig-work/#findComment-6102967
Pickle paste and scotch bright pads and they will look a million bucks. The secret is to run back over your weld without filler rod will make it nice and smooth also try a small weave to get your nice half moon shape
https://www.sau.com.au/forums/topic/382472-abes-tig-work/#findComment-6104303
If you cut your joints tight enough, you can just fusion weld (no filler) pipework in the first place. Not as strong though.
It never occurred to me to go around again... Isn't that cheating? :whistling:
I wish I could weld like the contract pipe welders we get in at work; theirs just looks like a robot did it.:worship: Still if that was all you did 12 hours a day; you'd want to be pretty good.
https://www.sau.com.au/forums/topic/382472-abes-tig-work/#findComment-6104423
You could also try the "walking the cup " style of welding to help with consistency ;-)
For stuf like intakes and cooler pipes I only do a nice hot fuse but try and roll the pipe so I get in one run ...
It's only a fuse weld but is still a full weld and plenty strong enough for cooler pipes and intakes!
As for going back over the welds I use to think it was cheating also lol but it's not that uncommon of a practice In the last year I have heard heaps of ppl say that's what they do hahaha
Although if it was structual I would do a nice hot root run first make sure u have peno first then go over it if need be
https://www.sau.com.au/forums/topic/382472-abes-tig-work/#findComment-6104531
I fuse as well but in his case to do a run over will make it nice and neat it is cheating but can save a ugly weld but after a while you can just tack 4 points and fuse right around looks wicked when you get it right. I tig almost everyday and when scratch tiging on site the run over can get out the lumps makes it easier to clean.
https://www.sau.com.au/forums/topic/382472-abes-tig-work/#findComment-6104703
use a eBay ac/dc welder I have one has never let me down they are good for the money but if you want to spend 4 g on one get a lincon they kick ass and have all the things you need. eBay ones do the job just as well iv had mine for 3 years now
https://www.sau.com.au/forums/topic/382472-abes-tig-work/#findComment-6105171
tig welding takes practice as with anything. i think its harder then mig and about the same as stick to learn.
just got to practice as with anything else... the more you do the better you'll eventually get
https://www.sau.com.au/forums/topic/382472-abes-tig-work/#findComment-6105568
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
