Hi All,
I realise this isn't a Skyline question, but I thought i'd see if anybody can give me any feedback.
My old man is restoring / racing John Atkinson's original 1984/85 Subaru RX Turbo rally car. The build date is a bit iffy as the car was a factory special build and was never fitted with a compliance plate.
He was asking me about fitting an aftermarket fuel only computer. I had a hunt around any couldn't find any direct plug in systems like the good old power fc. Does anyone know of any ? Or can anybody suggest a cheap(ish) easy to wire in fuel only computer ?
Thanks in advance,
Jeff
https://www.sau.com.au/forums/topic/382478-aftermarket-ecu-for-1985-rx-turbo/
I used to own one of those (street version)
had it dropped on 17" simmons - looked fairly tough.
. mate of mine used microtech on one . the thing would never start the second time around. (this was 10 years ago - they man have gotten better since.)
if its a rally only special with full cage post up some pics.
ECU - autronic or motec. may as well make use of the antilag option :)
Cheers - thanks for the info guys.
Yeah I'll take a few pics next time i am over in Victoria. Actually come to think of it we are doing the BLCC Xmas Autcoross - i'll take some action shot then.
Thanks again,
Jeff
well, i can pretty safely say that any info u want or need, PM me, i had a pretty ballistic 430whp ea82-t powered 1985 rx turbo leone. I ran a haltech and still had the stridubutor. we used a an early honda civic optical internals in the original housing so it would work properly with the haltech. i think it was an old F10-x from memory. Oh, and buy a few headgaskets and lifters, youre gonna need them. If you want to get serious with it, i have the numbers and drawings for a set of custom forged pistons we had by SPS in SA, from JE blanks and we got a set of Rods made by manely. Any sort of boost increase over 12psi will require an Oringed block. For a cheap and easy upgrade the early liberty RS turbo's are a bolt on affair, and much larger than standard. You can get 280zx injectors for a drop in upgrade too :)
Cheers, Allan
Cheers, Allan
Far out - that sounds serious! The engine is forged build already (o-ringed, forged pistons, rods, etc etc etc etc) I think from memory it runs 14PSI, also runs a custom built clutch, clutch fork and thow-out bearing, along with an adaptor plate into a liberty gearbox as it kept blowing the standard RX turbo box (even with oil coolers & pumps everywhere lol) He mostly uses it for Autocross events now, as being a factory special built car it's a bit of history that shouldn't be crashed lol...
Thanks so much for all the info, i'll pass it along and keep in touch...
Jeff
  • 4 weeks later...
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
