I fitted a Mallory distributor to the C210 last weekend, and was very pleased with the results. I plugged it into the existing wiring and it worked greatly.
I also had a go at fixing the electric fan that has been playing up (running continuously when the car is off/cold, and failing to run when the car is hot.)
Unfortunately, it seems that the two problems are linked. The fan is still continuing to play up, and the ignition module for the lovely new distributor suddenly fried on Tuesday. I used a multimeter and found that the + and the - from coil to distributor both have power. That's not right is it?
I think there must be a short somewhere that is causing the fan and distributor both to fail.
https://www.sau.com.au/forums/topic/382499-c210-wiring-woes/
  • 1 month later...
Update. The car ended up stranded at a radiator mechanics (given I initially wanted a new switch soldered into the radiator) with a dead ignition module. I supplied another distributor and gave permission for a them to have it towed to a local auto electrician to sort out the wiring, and hopefully kill two birds with one stone (revive the buggy fan and stop the new ignition module from frying).
Anyway, the auto-electrician kept the car for over a month. Finally I got a call from the radiator guy saying the car was finished and running again, and they would go and get it in the morning. I expected to get bent over by the auto-electrician, and sure enough, the radiator guy told me that the auto electrician's bill had run up to $700 odd.
WTF? I don't remember giving anyone permission to clock up the better part of a grand's worth of... wiring. That's over a day's labor to find and fix a short and swap a distributor.
Any suggestions on how to deal with this?
After grumbling on the phone a bit, when I arrived it turned out that $700 was the total for everything: an hour's labour at $100 for the radiator mechanic to call a tow truck, $80 for the tow truck, $100 for a standard bosch coil (source of wiring oddness), and 5 hours labour at $95 an hour to fit the coil. Greaaaaaat...
Anyway, I did some homework with consumer affairs; turns out a mechanic has every right to hold your car for nonpayment. The onus is on you to demand a quote before the mechanic starts work (or at least an estimate), force them to call if it's going over budget, find out what the mechanics labor rate is, and to find out what they will charge for any parts likely needed (I can tell you now if I knew they wanted $100 for a $50 coil I'd have told them to stick it on principle alone.)
The long and short of it is find out if you are going to get screwed before you hand the keys over, cause there is probably bugger all you can do about it once you have.
Better yet, fix your car yourself!
5hours labour to replace an ignition coil? It's two screws, a plug and a couple of terminal nuts. 10-15 mins TOP! That being said, tracing electrical problems, even even in old cars, is troublesome and time consuming at the best of times. Also, its never a good idea to get a workshop to send you car anywhere else as they will add their own markup to what the other guy charges as well. If it has to go elsewhere, take it yourself.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
