Hey guys,
Got some things I really don't need lying around:
2 x R32 Tail-lights (White Surround, Ie Both Sides) - $150
2 x R32 Windscreen Wiper Motors - $25 ea
1 x Passenger R32 GTSt Seat (On Rail) - $120
1 x R32 GTR handbrake - $10
Various Interior parts:
- Centre Console - $50
- Part that goes around the dash cluster - $10
- Part that goes around the centre console - $10
1 x R32 GTR ABS unit - $200
1 x R32 GTR Alternator - $100
1 x R32 GTR Starter Motor - $100
4 x R32 GTR standard Suspension (full set) - $300 ono
Give me some ballpark figures. You know what most of these parts are, but if you are interested I could get pics. Some parts may not be suited to freight.
Thanks,
Rick
https://www.sau.com.au/forums/topic/38250-r32-parts/
Hey guys,
Sorry about the delay, I have been busy.
Its not the panel that goes around the gearbox surround and up around the cluster/gauges/stereo. It goes BEHIND the dash, if you look at your interior side on you'll see a panel going toward the front of the car, on both sides of the middle of the dash, and thats it :D
You might have a boost controller or a turbo timer or something stuck to the side of it..
lwells: Sorry, don't have them :)
Nismo_286: Yep, got that complete in one piece, $50 :)
https://www.sau.com.au/forums/topic/38250-r32-parts/#findComment-775261
NickySantoro, do you have the part number of the ABS system on a 33GTST ? Knowing Nissan they'd be the same, but it'd be good to be sure.
CerealKiller, the condition is average, a little bit of wear but its not really peeling off. Looking at the windscreen wiper motors, I've got 1 x front and 1 x rear, so this one is avail to suit yours if you want :mad:
https://www.sau.com.au/forums/topic/38250-r32-parts/#findComment-796360
Appreciate it man...
Once i see the pic, i will reply back to you...
Cheers.
Sorry Nismo_286, been busy, i'll post up a pic of the thing tonight.
I'd prefer not to bucher it but I spose $20 plus freight if you want it, its in good condition.
Cheers,
Rick
https://www.sau.com.au/forums/topic/38250-r32-parts/#findComment-796667
  • 5 weeks later...
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
    • I promise there will be no chance of replacing the rad support....  It is barely twisted and it's way more likely to just be driven around with a slightly twisty support. As long as the headlight can be bolted in there then no harm no foul lol. The reo may need to be un-bent a little but truth be told if it all somewhat lines up and is hidden when the car is assembled the level of f**ks will be 0.0
    • this thread delivers, once again Skyline owners, our cars spend more time off the road than on the road
