Item: R32 non-projector Headlights w. clear lenses.
Item Condition: Very good, slight dimple where headlights have been hot
Reason for Selling: Parting out
Price and Payment Conditions: $300.00 ono
Extra Info: Will include bulbs.
Pictures:
Item: FRP Bootlid, not china shit hand made in NZ
Item Condition: Will post
Price and Payment Conditions: $400.00 ono
Extra Info: Extremely good fit, amazing quality, painted black. Bood lock and latch can be installed, metal behind where hinges bolt up.
Pictures:
Item:[/b ] [color=#1C2837]Kakimoto Regu 06 (suit r32 gtst / gtr) w. [/color]3" SS dump pipe w. flex joint and Highflow Catco Cat
Item Condition: Very good, apart from usual dings / scratches (see pics), comes heat wrapped in sections.
Reason for Selling: parting
Price and Payment Conditions: $450.00 ono (f**king cheap)
Extra Info: amazing exhaust, very quiet.
Pictures:
Item: UAS style (possibly Silkroad) R32 gtst/gtr upper camber arms
Item Condition: Good
Price and Payment Conditions: $150 ono
Extra Info: Good, were modified for longer LCA, can revert to standard by cutting washer slot (see pic)
Pictures:
Item: R33 Clutch Master / Slave w. Braided Line
Item Condition: Great
Price and Payment Conditions: $150.00 ono
Extra Info: $100.00 worth of braided line
Pictures:
Item: Dmax Style R32 Rear Overfenders
Extra Info: there about +20mm
Pictures:
Item: Dmax Style R32 Front Overfenders
Price and Payment Conditions: $100.00 ono
Extra Info: there about +20mm Front Passenger has crack / indicator slot broken (can be fixed)
Pictures:
Item: Clear Indicators
Extra Info: chip from bottom corner, slightly tinted.
Pictures:
Item: FRP gtr style front bar suit GTST
Item Condition: Excellent, few cracks in lip
Extra Info: this is not cheap shit FRP, this is an extremely well made front bar, had bonnet pins in it for quick removal. Painted Black with Bumper trim black Lip
Pictures:
Item: R32 Coupe Vertex Side Skirts
Extra Info: there painted black
Pictures:
Item: R32 Vertex Rear bar
Extra Info: painted black, comes with reverse lights
Pictures:
Item: Personalized Plates
Item Condition: Good, one was involved in accident, but bends straight, new plates are $70
Price and Payment Conditions: $500.00 (what i payed)
Extra Info: FAP 32, epic plates so many compliments
Pictures:
Item: Enkei RPF1 MAP (the light weight one these are 8.9kg each)
Item Condition: Immaculate, tiny mark on one rim.
Price and Payment Conditions: $2000.00 ono with tires
Extra Info: 18x10.5+15 - 265/35 Falken 452's
Pictures:
Item: R32 gtr rear windscreen
Extra Info: gtr windscreens supposedly are lighter.
Pictures:
https://www.sau.com.au/forums/topic/382539-parting-r32-gtst/
  • 3 weeks later...
wide body front and rear guards SOLD !!!
Camber arms SOLD !!!
wheels SOLD
vertex skirts - $80
vertex rear bar - $120
rear screen - $280
bootlid - $350
number plates and exhaust system still here.
Edited by 32_Dave
  • 2 months later...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
