  • Replies 48
i measured back pressure on a -10 equiped rb2630 we had at work that just would not makle power over 18psi.
on 14psi there was 25psi back pressure. on 18-20psi it had 35-40psi back pressure.... (30psi boost guage the needle wraped around to 0.. and our dyno can only read 30psi.
What power did that particular engine make on your dyno?
Just need someone with 2530/-5 to take the plunge and try a cropped GT30 exhaust wheel as above and use the HTA 68 front wheel and hope for the best! If its to laggie 3ltr it!!
you want me to try what? :D
i'm in Melb, dealt with Stao quite a bit before with my GT-T, nice little high-flow on that car, punchy little number.
So what are we trying to do with the 2530's? in laymans terms, i'm terrible when it comes to turbos, other than a 3071 is less laggy than a 3076, basic crap like that :D
are we trying to make them more responsive and powerful at the same time, or just more top-end out of them? I'm running 2530's in the R
Attempting to push 2530's harder! Whats the consensus of whether to open up the entry to the wastegate flap on hks 2530's? More area on the flap would apply more force to blow it open?
These could be my next upgrade (4th set) of actuators the dual ports look real nice!
http://www.full-race.com/store/turbos/borgwarner-efr/efr-dual-port-internal-wg-actuator.html
Now i wonder if running boost pressure to the bottom side of the gate will enable me to crack 30psi up top with the 19psi actuators or head straight to the 35psi units? Be interesting to see base pressure with the 35psi ones! :domokun:
The reliability of the stock extruded manifolds are great but at 460awkw i wonder if theres power there aswell?
Nice looking actuator!
Where did you get the manifolds extrude honed?
Berry's GTR used to be (still is?) on stock manifolds, surely they'd know if it's a restriction so maybe call CNJ Motors in Queensland and see what they have to say?
UAS organised the honing back in 2004 not sure if there still doing it..
Maybe hypergear could join the conversation with a few options on high flow bolt in low mount GTR turbo's that give 50-60AWKW extra than current offerings without masses of lag??
    • Por qué no los dos? Body colour red with black stripes down centre, onto bonnet and bootlid.
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
    • Yellowjackets, red ones, blue ones (other than Splitfire) have all been demonstrated to be unreliable on turbo engines. That unreliability can be anything from outright failure (ie, 4 out of a set of 6 working out of the box) to just not being strong enough for the task, on a boosted engine. Not enough of us care about NA engines to know whether that unreliability is an issue for the undemanding needs of an NA RB20. I should think though that the DIS-008 should fit the 20. There's not really any reason for the head/coil mounting area to be any different on those 2 Neos. I wouldn't be buying Splitfires, or any other old tech coilpack, for a car in this day and age though. I would buy modern pencil coils and do what needs to be done to adapt them to the loom. That's relatively trivial these days, with numerous kits for fitting R35, or Audi, or Yaris/Corolla coils.
    • Keen to see how much work is needed to get an abandoned Skyline going. My R32 has been sitting idle for three years or so but finally got some time to get it going again. (Also lurking SAU and trying to hit 10 posts so I can start my own intro thread with pics)
