hey guys,
Wondering if anyone might have a ring gear stopper for an rb26 I could borrow?
I've tried everything I can think of to crack this crank bolt.. It ain't coming off.
I've tried:
3m breaker bar trans in 4th
wooden block on chasis rail then cranking the starter
breaker bar tensioned then belting it with a 1kg hammer
holding the fly in place using two flat end screwdrivers
couldn't fit a rattle gun without moving the condensor...
I'm finding it difficult to get enough of a sudden jolt onto the crank bolt, hoping if I can hold the in place I might be able to crack it with my breaker bar.
Any help would be greatly appreciated!!
https://www.sau.com.au/forums/topic/382559-ring-gear-stopper/
I found it easy to do it this way.
1. Take out radiator and Clutch fan
2. Put car in 5th, so it is over a 1:1 ratio
3. Put correct size socket with breaker bar onto the bolt
4. Hop in the engine bay and jump up and down on the breaker bar
...worked for me :P
I have heard of people making sure the end of the breaker bar is on the ground and then turning the engine over...but that is a rather bad way of doing it I would say.
Hey Aberax,
Cheers for the suggestion, however I can't seem to get enough of a sudden shock while using this method. My crank simply turns over, mind you this is with the vehicle on a set of ramps, hand brake up and back wheels chocked. I really need to lock the flywheel then use this method.. ;(
It's on there BLOODY tight... That's for sure.
You need one of those tools that you hit with a hammer. I ended up having to buy one for the same bolt. Cost me over $100 but does it easy. I'll see if i can find a pic.....
One of these. They say they can generate 500nm of torque, I say they aren't using a big enough hammer. You will be able to undo it with the car out of gear so you will avoid putting load through the drive train.
I may lend it out for liquid renumeration
Edited by Race__24
When I had my 100,000km service done, we used a breaker bar against the chassis. My battery wasn't enough to do the job, but his big ass BMW battery (I think from a 4WD) loosened it first try
Yea Ive got a 550CCA battery if that method was going to work im sure it would have after the first 5 > 10 tries :)
There is a really easy way of doing it,
Socket and breaker bar on crank bolt, place it so the handle of the breaker bar is leaning against the chasis rail/inner well on the undo side or as close to as possible, disconnect your ignition system (unplug coilpack loom), give it a quick short crank with the key, Presto!! Starter motor does all the muscle work for you :)
Edited by SkyHi_33
ive been looking for one of these for a while now.. where did you get yours from?
Y not go the slip knot rig? Easy as pie! And costs f**k all!
Old bike tube cut up, slip knot done to tighten itself as your pulling.
Breaker bar, i cut down a no parking sign out the front of my house for added leverage ;)
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
