The 2600k is i7 branding also not just i5.
http://ark.intel.com/products/52214/Intel-Core-i7-2600K-Processor-(8M-Cache-3_40-GHz)
Same price too, why not i say!
i7 branding is only good for e-penis length :P
Plus it's ~$100 more expensive, not the same price.
  • Replies 47
1321915308[/url]' post='6120664']
1321919677[/url]' post='6120772']
:laugh:
Exactly what i thought when i read it :whistling:
Well said! that's why I gave up! Cant believe I was dumb enough to try. So how did you overclock yours. I know enough too just leave it alone
Without looking into it i would say they would be higher binned chips potentially.
This is usually the way such things work (same as steppings) leading to better overclocks also.
Will do more reading especially with the 2700k coming out shortly and overclock results starting to crop up - but some people are getting 5.0ghz on AIR from a 2700k where most 2600k are 4.6-4.8 on air from what I've ready.
Very keen to watch how they go.
i have that exact same board. well, actually, ive had 2 of them now >.< had alot of issues with them heating up and sharting themselves. ive gone to an ASUS board now, see how it goes. On a good note, the warranty was a fast turnaround and good response time from gigaflop.
1321953481[/url]' post='6121778']
Any results for what they get on water?
Thinking back it was the gtx295 that was 30% overclocked not the CPU, only did the shaders and gpu, didn't do anything with the voltages. The CPU was just the multiplier spreadsheet said I had +4, i was trying to go from 3.02 to 4 or 4.5, which was meant to be easy on water, but once again I didn't set voltages just left them on auto. Time to find the overclockers forum I guess.
Depending on the board auto can be much much worse than setting the voltage manually.
1322174207[/url]' post='6125735']
The board is gigabyte GA-EX58 Extreme, so may be a got some bad advice then, I was told with that board it was best to just leave the voltages at auto, this probably explains all my problems
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
