Ok so i picked up a set of hks cam shafts for my nur spec motor.
they are
hks 10.08 lift 264s
hks 10.01 lift 264s
Could some one please explain how these will differ from 9.15 lift 264s pon cams?
What am i gaining from more lift ,These do not seem to be a off the shelf set of cams correct me if im wrong.
My current set up is hks25/30s.My motor droped a ring lan was making around 460-470 on a hub dyno hp atw stock cams
Looking at going a single turbo set up around the 700 to 750 hp mark turbo.
These cams suit this set up?
https://www.sau.com.au/forums/topic/382596-cam-shafts-rb26-264s-1008-1001-lift/
They are close in spec to the jun 264 9.7 cams I run,
The poncama are 260 so you have a bit more duration, which tends to shift the power band a touch higher in the rev range. The extra lift gives more flow. I havn't heard of the specs of these cams before, you sure it's correct.
yep i have em sitting here in front of me mate they are stamped this way.
Bought em from jpn and thought that lift was a bit odd.Was going to use them with the 25/30s thought it would give me a little more top end.
they are odd tho yes?
must be a custom job i think
Edited by Gtir-keiron
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
    • Can you covert an R32's AC from r12 to r134 if the compressor/hoses etc are still all good? Pretty sure on my car the AC was degassed when it was imported  to remove the naughty r12 and save the ozone layer, and the fancy climate control system just blew air around. Was happy to drive the car with windows down back then, but now I am old and need to be kept cool
    • Just to circle back here, I've sold my automatic trans to another Stagea owner in OH.
