5 SPEED MANUAL
Truly a weapon people, that's all I can say. I've had this car for about 1year and enjoyed every second I had with it.
This BEAST has 250rwkw Tuned by the boys down at UNIGROUP Engineering. Installed New Exedy cushion button Clutch recently.
Its done about 89,xxxkm.
Its had full GTR Replica Body work done to the front of the car which fits perfectly to the GTT by East Bear. Not many like this one going around in Sydney.
This car is in great condition, you will not find one that has been better taken care of. Always serviced on the dot and with top products - no cheap alternatives. This sale is extremely regretfull and would suit any extreme performance vehicle enthusiast. Please dont hesitate to call me with any questions in regards to the vehicle. Any reasonable offer will be considered
ENGINE
RB25 Standard Internals
T430 Internal wastegate Turbo
ID725CC Injectors
Front mount Intercooler
Walbro 255 Fuel Pump
Z32 Airflow Metre
NISTUNE Board remapped ECU
GFB BOV Plumbed back
3" Turbo back exhaust (special ultra Hi-flow metal cat)
BMC Cold Air Intake
NGK Iridium Spark Plugs
Splitfire Bluetop Coil packs
INTERIOR
Full Offwhite Leatherette Interior…
Red LED lights with switch
Pioneer head unit
Pioneer 6" speakers
Reflective Tint 15%
Custom guages installed BOOST, Vacumm, Water and Battery
HKS Turbo Timer
EXTERIOR
Full CUSTOME/Eatbear Bodykit
19" HIRO RIMS
DBA Slotted Rotors front
NISMO Side Blinkers
Dropped on King Springs
ASKING PRICE: $19,990 ONO
CONTACT: 0400 899 981
  • 1 month later...
  • 5 weeks later...
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end a made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
    • As someone who has pineapples, and horrible axle tramp... should I change these to collars? Is that what you're saying here? Why did you choose these instead of getting pineapples where you said you had good experiences of? I'd love to even attempt to get rid of axle tramp, I either get complete bogginess or absolute insane wheelspin, anything even remotely in between results in filling-removal axle tramp, to the point where launching the car is just not something I do.
    • Lucky for that, because putting ethanol in fuel only lowers the bulk cost of fuel if it's in 91 Add it to 98, 85% of it even and it quintuples in price. Strange physics. f**k you United, Gouging c***ts.
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
