5 SPEED MANUAL
Truly a weapon people, that's all I can say. I've had this car for about 1year and enjoyed every second I had with it.
This BEAST has 250rwkw Tuned by the boys down at UNIGROUP Engineering. Installed New Exedy cushion button Clutch recently.
Its done about 89,xxxkm.
Its had full GTR Replica Body work done to the front of the car which fits perfectly to the GTT by East Bear. Not many like this one going around in Sydney.
This car is in great condition, you will not find one that has been better taken care of. Always serviced on the dot and with top products - no cheap alternatives. This sale is extremely regretfull and would suit any extreme performance vehicle enthusiast. Please dont hesitate to call me with any questions in regards to the vehicle. Any reasonable offer will be considered
ENGINE
RB25 Standard Internals
T430 Internal wastegate Turbo
ID725CC Injectors
Front mount Intercooler
Walbro 255 Fuel Pump
Z32 Airflow Metre
NISTUNE Board remapped ECU
GFB BOV Plumbed back
3" Turbo back exhaust (special ultra Hi-flow metal cat)
BMC Cold Air Intake
NGK Iridium Spark Plugs
Splitfire Bluetop Coil packs
INTERIOR
Full Offwhite Leatherette Interior…
Red LED lights with switch
Pioneer head unit
Pioneer 6" speakers
Reflective Tint 15%
Custom guages installed BOOST, Vacumm, Water and Battery
HKS Turbo Timer
EXTERIOR
Full CUSTOME/Eatbear Bodykit
19" HIRO RIMS
DBA Slotted Rotors front
NISMO Side Blinkers
Dropped on King Springs
ASKING PRICE: $19,990 ONO
CONTACT: 0400 899 981
  • 1 month later...
  • 5 weeks later...
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
