Hey guys & girls
Thanks to the EPA, I am after a factory airbox so that I can get compliance.
I have an r33 gts-t, series 1.5
I am in the Mornington peninsula area, Victoria. Will travel around Melbourne area to pick up item.
Thanks -Kieran
https://www.sau.com.au/forums/topic/382637-wtb-r33-gts-t-factory-airbox/
Hey guys & girls
Thanks -Kieran
gday there kieran , how are ya man , was wandering i can do you a deal on a D.R.I carbon fibre cold air box enclosure too suit your car for = $370 each man .
since i know i needed it to be enclosed wen i got defected so i am running 1 on my street ceffy now :)
wil send a pic
let me know if your interested ok man
talk to you soon
thanks anthony
wil send a pic
talk to you soon
thanks anthony
Sorry mate I need the factory original airbox to get compliance from the epa emissions and exhaust test - You are only allowed 1 intake modification, and my car has both a modified air intake and intercooler. So I need to return the air intake to factory to pass it. It is already enclosed, full custom set up but according to the epa tester, it has to be factory standard.
Any offers? Will pay cash.
gday there man , wats happening ? nah thats cool man , just thought i throw it out there hey and try and help in anyway i can :) .
well good luck with it man and if i do come across any airboxes lying around be sure to let you know asap
thanks anthony
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
