Hey Guys
Been using the search function and prices are out of date for all the info
Just wondering what kind of piggy backs or stand alone ECU's I could pick up for my price rang of $600-$1000
I know a Nistune needs me to buy a r32 ECU or 300zx ECU.
Recommend anything?
https://www.sau.com.au/forums/topic/382666-good-r33-ecu-or-piggy-back/
i'd still go the nistune. even with a z32 ecu you should be able to get it all installed and tuned for about $1000. pfc does bugger all more (won't see you any gains in power) and will end up costing you much more. the money you save could be put towards other mods
but power fc, has some nice fatures, boost display, water temp, knock sensor etc. plus its instant install, easy peasy and close to every tuner on the planet will tune it. not to mention you can drop in injectors and run them out of the box by changing the settings with the handcontroller.
but then again, each to their own. you cant go wrong with either.
but i do have to disagree with the power gains. mine def has more power than before, havent had it on the dyno, but in first gear i can easily get my wheels spinning, which i could not manage on my standard ecu. thats in a 1600kg car in rwd mode with only a pod, exhaust and upped boost.
pretty much any tune will be able to tune a nistune as well.
to change settings in the nistune all you need is a laptop and a consult cable. and while the PFC may show a knock reading, the nistune will actually react to knock and back the timing off, just like a standard ecu (since that is what it is, a standard ecu that you can alter the mapping of).
and i never said that a pfc wouldn't give you gains over a stock ecu, because it will. however it will not give you power gains over a nistune with the same tune on it.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
