  • Replies 130
Good job on the research, saves tears later.
As before; I'm in for 2 sets, PM me some details & I'll cash you up.thumbsup.gif
Cheers. I just hope my research is correct :)
Shouldn't be a prob, if anything like the guy from SPC Performance said, the bolt might just be a few mm long but it's not a problem. Better a little long than short.
I'll PM everyone payment details Wednesday night.
Edited by slippylotion
Ok guys, the chance to get in on this buy is now closed.
I will PM everyone listed below the bank details and final price excluding postage within Australia from me to you.
Please don't pull out of this now as the final price everyone gets is worked out on everyone listed below still paying.
The guys in the buy are:
Slippylotion (myself) x 2 sets
Daleo x 2 sets
Scotty nm35 x 2 sets
Commsman x 2 sets
prince_skyline x 2 sets
skip_o_valov x 2 sets
Thanks everyone for getting in on this so we all save a bit of coin on these.
The shipping from the US is standard international so please allow a few weeks for arrival. As soon as they arrive I will contact you all to arrange postage to you.
Cheers
  • 3 weeks later...
The bolt kits are here guys! Just in time for christmas holidays to fit them on that lazy day.
PM will be sent regarding postage to each of you.
Thanks a heap guys for joining in with me.
Cheers
No problem, so what do we use to slot the hole? Is there any instructions?
The square white piece of card is a template for marking out the wider slot; you just colour with a marker pen and use a die grinder with a rotary burr or dremel to widen the slot.thumbsup.gif
Yeah they come with instructions. Can use either a dremel or die grinder. Maybe a bastard file if you have plenty of strength and time ?
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
