  • Replies 130
Just keep the SPC bolts in mind. With my ride height at 350mm F and R the rear camber is now at -1.25deg with more adjustment left. I would assume a lot cheaper than a set of arms and no rose joints.
part number for the Super Pro stuff
http://www.superpro....art?id=SPF2849K
PS: Unless your local has them I don't think there are any in the country atm! I used all the stock and the next order! :P I have been waiting for the next shipment for about 4 weeks now.
Edited by Jetwreck
Pretty sure this is what I was looking at, it was one of the control arm bushings I needed to replace: http://www.superpro.com.au/find-superpro-parts-for-my-vehicle/part?id=SPF3297K
White line do some similar that are cheaper but theyre not eccentric.
Whiteline have these eccentric ones (http://www.whiteline.com.au/product_detail4.php?part_number=KCA331&sans_vehicle=1) for heaps of Nissan models. Wrong ones??
There is offset bolts from factory but the SPC bolts I did the GB on give another 1-1.5 deg adjustment and cheaper than a/market arms. A/market arms usually also add rose joint ends to them adding a bit of NVH. The only rear M35 a/market camber arms I have found are a Jap unit the cut and shut the factory arm to give adjustment with a rose joint end, these from memory are around $600-700 delivered!!! I haven't found another a/market camber arm as yet as the M35 camber arm is different to the V35. All other rear arms seem to interchange with the V35, just not the camber arm.
I thought that the cam bolts were in the lower arm (the one with the spring cradle) not the caster rod?
They are. The castor rod is at the front of the car.
The arm in the rear that seats the spring is the toe arm and the lower arm that the shocker mounts to is the camber arm. These both have offset bolts for adjustment but it's limited.
The other arms are the upper control arm and traction rod.
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
