I'm not trying to be a smart arse by this comment but I am confused! I gather you are all talking about setups after coil overs/lowering.
A/ Are your trying to sort out the best tyre wear setup?
B/ Are you trying to work out the best handling setup?
If you are trying to work out the best handling setup your wasting your time unless you get your caster done followed by corner weighting, ride height and then the wheel alignment. Then go to a track and set up your shocks and sway bars to your driving style.....you also need to look at your bump steer...then back to the wheel alignment giving them feedback on how your car was acting!...just a short summary of what you need to do imo!
All of this will be irrelevant in 10,000km as your chassis will have changed anyway because more than likely you have no bracing.
P.S. This is why I hate fully adjustable coil overs for street unless your after stance that is!
Just trying to add input......I know these wagons handle.....but its to what extreme you want them I guess!
Edited by Jetwreck
  • Replies 130
Probably a one shot deal but I could do another if enough people want them. Since I'm sorted with a set I would probably charge an extra few bucks per 2 sets to cover my time organizing it. It would roughly be about $60 delivered to Adelaide for 2 sets in a GB.
Edited by slippylotion
Sorry one other question:
Are the bolts you replace the ones that are offset?
Obviously the added adjustment in the SPC kit comes from the fact you are elongating the bolt but are the replacement bolts, if any, also offset?
For me it's getting a correct alignment for tyre wear on the street. I myself don't see these cars as a track car being so heavy and auto, so I wouldn't go that way, others might like to track them though.
I just found that running my ride height at 350mm F & R I had basically maxed out the rear adjustment and was still running 2deg neg camber. These SPC bolts gave the extra I needed with a bit left over.
That arm won't fit the M35, it will only fit the V35. M35 has the mount in the arm for the shocker to bolt to it where as the V35 shocker does not bolt to that arm.
The cradle in your pic is an M35 cradle as you can see the bolt still in the factory arm where the shocker bolts to it. Notice that a/market arm has no place for the shocker mount bolt.
This is the factory M35 rear camber arm modified in Japan by a company called Nagisa Auto and cost 85,000 yen in Japan, so well over $1000AUD via Streeter or Import Monster.
Hey Craig, nice summary of suspension setup. For me the lowering was 90% for looks (that's one reason I went softer springs on the BC's) & so these bolts & other bits we're all discussing are to help with tyre wear, for me anyway. The handling on my car is more than adequate for street driving with what's been done to date.
I'll talk to the bloke in the morning, since he told me he had a set on his NM35. If it ends up they don't fit, I'll be ordering a set of the SPC bolts if anyone else missed the first order?
This is the M35 castor rod. http://www.japaneseimportspares.com.au/itemdetails/28594
You would use the bush that Craig linked that is offset to gain more castor.
So the bush that Craig linked needs to be pressed onto the rod?
The old bush would need to be pressed out. I'm not sure if the new bush can be pushed in by hand, I could easily do this with the super pro front upper arm bushes, pressed out with a press and pushed back in by hand. Otherwise you would need to press them in.
If you have time just remove the castor rods yourself then drop them off to get the bushes removed/installed and then refit the arms yourself. It should cost less than $100 to get the bushes done.
Ok there's a few guys keen so I'm going to place an order. Except when Paul ordered them they were $21, now the web site is saying $48.82?
Anyway, if you're keen, let me know and let me know how many sets you want.
So far I think we've got:
impul535w x 2
Ironpaw x 2
If there's anyone else let me know, probably order late next week depending on the exchange rate.
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
