Dude the whole things gonna cost you around 5K-6K, if you want genuine eastbear parts
If not, you can probably get a fibreglass kit, which in my opinion is not worth it because over time the maintanence costs will exceed the cost of the original parts.
In my opinion you should just get an eastbear front lip of nengun or rhd, which makes the gt or gtt front end look beastly, and replace the side skirts and rear bumber with some other bodykit.
Hope this helped you out.
I can source the kit for you at list price( just depends on the dollar as its been quiet volitile the last few months) again as Matty said shipping is a bitch. But it just depends on which shipping option you want. You can have it done door to door which is the most expensive. Or you can have it packed in a container with other parts which with cut you shipping costs by more than half. I can give you a quote. Just pm me if your interested :-)
i didnt realise you were a registered trader on SAU?
we operate below list price, passing on the discount we get from EAST BEAR being a genuine EB dealer
No matty im not a registered SAU trader, just someone who knows who to talk to, to get stuff and likes helping people out.
I didnt realise this was the traders forum ?
Shouldn't trading be keep to appropriate traders forum instead of whoring for business in regular forums.
Just pm the guy if you want to sell parts and keep the regular forums for what they are meant for.
Other traders seem to be able to do that .
    • Yeah. I believe the fear of annealing the alloy and weakening it, Every online discussion has someone saying it's bad and potentially a risk when powder coating forged wheels.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
