Oh man, first time someone has given me a proper forum insult "umad"... brilliant; cheers for the quote though champ.
Thanks Brad was waiting for you to chime in... oh and mate can you email me still keen for that sump!!!!! Getting drawing of my custom designed pump, will send through details for your interest.
Was the reason the Japanese GT cars went with RWD platform for their GTR's to do with rules or for the reliability, weight improvements?
Edited by bigmikespec
  • Replies 67
I am approaching this from the opposite direction R33 GTS-T to GTR running gear.
At this point I have a GTR dash, seats and trim installed.
I am currently building a full GTR cradle and diff to drop in with Bilstein PSS9 shocks for the December track day.
I have modified GTR Bilstein PSS9's to fit the GTS-T front suspension and retain the correct ride height and adjustability.
I also have all of the GTR additional braces for the floor, behind the motor and inside the boot to stiffen up the chassis.
Next on the list is a full set of GTR Brembo brakes to complete the running gear.
If I really start to get serious I also have a full GTR front (guards, bonnet, front bar, reo, grille etc) that I had painted to match the car when it was resprayed packed away in the shed.
I hope to have the handling and performance of a GTR, with the running costs of a GTS-T and lap times somewhere between the two.
japanese GT cars have set specifications, like pretty much every other racing category. that is why some of the GTRs were rwd. it is also the same reason the R35 GTR's run in rwd and are powered by a 3.4L V8
^yup
R32 GTR's were always run in awd and spanked everything which is why the series moved to rwd, to even out the playing field. I'd say though that the spanking at the time of the 32's was more to do with the fact that the cars were so far advanced in all aspects compared to the rest of the field, and not just cause they had awd.
It's actually pretty intersting though that most categories make awd cars convert to rwd to even things up?? Maybe your answer is right there :)
japanese GT cars have set specifications, like pretty much every other racing category. that is why some of the GTRs were rwd. it is also the same reason the R35 GTR's run in rwd and are powered by a 5.6L V8
fyp :)
R32's raced under group A regulations nothing even remotely similar to the current GT categories.......
What current categories (defining most not just one or two) actually require RWD converted cars.
NASCAR makes Toyota turn a camry from FWD to RWD and run a copy of the Yates 357 Windsor lol ;)
Been here done most of that......
My old R32 GTR which was raced not just tracked had a terrible issue smashing front diffs off the grid.
I'd get the first race down and the rest of the weekend would be spent with a crownwheel floating around in the front diff.
The car would be very difficult to drive when the front diff would first let go. After some chassis work to make livable I would end up leaving the front diff broken for the rest of the weekends
Nothing else would change just no front diff.
Perfect example of why brad should keep using front diff's :P
white GTR front row of the grid
Obviously not categories for us here, but the ones i was thinking of - GT1, Super GT, JGTC (not sure 33's, but 34's were rwd) DTM, Sport Sedans (i think)
seen that launch allot better, that gtr won powercruise of street drag racing not to long ago, also does mad 4 wheel hellis
I've actually launched that car alot better I'd agree.
As for winning some drag race I doubt it. The car was retired after that race meeting and hasn't turned a wheel since.
Infact I built the car and it never even seen a drag strip during my ownership.
4wd hellis from that car I highly doubt too, it ran a 330 slick front and rear that cost more than most peoples rims and tires put together.
Edited by Risking
Diff explosions were more caused by the transfer case experiments.
We could make a diff survive during qualifying due to the rolling starts, the shock loading put onto the tiny diff from the transfer was doing the damage. The failures were almost always stripped crown wheel teeth.
It didn't matter if the car had small AO48's or dunlop's michellins etc you had to slowly feed the power to the front from a standing start.
Factory transfer case problem fixed but car slower.....
It seems that a GTR in rwd form, purpose built that way would more then likely be better then a straight gtst. Purely due to the car having a better all round setup from factory. Slightly wider track, provision to run bigger wheels/tires which is quite important. This is severely limiting in a gtst. The most obvious one being the stance of the gtr makes it looks a hell of alot tougher then a gtst!
But in the end, if you have enough money you can make any car quick or quicker then your competitors, then you just need the skill to drive it. So eitherway is achieveable, Comes down more so to whats going to give more benefits for the least amount spent on it.
That is what I am thinking Mike.
It is a lot of weight and cost (from an initial stand point and also ongoing maintenance) to remove the front diff and transfer case and all associated components. Will make the dry sump pan easy too.
Also, instead of spending $10k on a PPG dog box you could spend a touch more and get yourself a refreshed used Holinger.
You know "guys like us" dont have enough money to make any car quicker than competitors :)
you would have to weigh up...whether it is worth buying a GTR for over 20k prob 25k then spending all the coin working on it to be rwd.
or buy a 33 gtst for 4k, with a cage say 7k, GTR front guards for a few hundred, fiberglass rear guards, chuck a RB25/30 in it + your hollinger
and you have a car that will be so close to what you want to do you would have to be Michael Shumacher to tell the difference is chassis rigidity
and it wouldnt cost much more than buying a Standard 33 R to begin with. then spend the 20k saved on not buying a GTR on some of Brads trick suspension bits and a dry sump setup.
its what I would do given the coin
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
