Oh man, first time someone has given me a proper forum insult "umad"... brilliant; cheers for the quote though champ.
Thanks Brad was waiting for you to chime in... oh and mate can you email me still keen for that sump!!!!! Getting drawing of my custom designed pump, will send through details for your interest.
Was the reason the Japanese GT cars went with RWD platform for their GTR's to do with rules or for the reliability, weight improvements?
Edited by bigmikespec
  • Replies 67
I am approaching this from the opposite direction R33 GTS-T to GTR running gear.
At this point I have a GTR dash, seats and trim installed.
I am currently building a full GTR cradle and diff to drop in with Bilstein PSS9 shocks for the December track day.
I have modified GTR Bilstein PSS9's to fit the GTS-T front suspension and retain the correct ride height and adjustability.
I also have all of the GTR additional braces for the floor, behind the motor and inside the boot to stiffen up the chassis.
Next on the list is a full set of GTR Brembo brakes to complete the running gear.
If I really start to get serious I also have a full GTR front (guards, bonnet, front bar, reo, grille etc) that I had painted to match the car when it was resprayed packed away in the shed.
I hope to have the handling and performance of a GTR, with the running costs of a GTS-T and lap times somewhere between the two.
japanese GT cars have set specifications, like pretty much every other racing category. that is why some of the GTRs were rwd. it is also the same reason the R35 GTR's run in rwd and are powered by a 3.4L V8
^yup
R32 GTR's were always run in awd and spanked everything which is why the series moved to rwd, to even out the playing field. I'd say though that the spanking at the time of the 32's was more to do with the fact that the cars were so far advanced in all aspects compared to the rest of the field, and not just cause they had awd.
It's actually pretty intersting though that most categories make awd cars convert to rwd to even things up?? Maybe your answer is right there :)
japanese GT cars have set specifications, like pretty much every other racing category. that is why some of the GTRs were rwd. it is also the same reason the R35 GTR's run in rwd and are powered by a 5.6L V8
fyp :)
R32's raced under group A regulations nothing even remotely similar to the current GT categories.......
What current categories (defining most not just one or two) actually require RWD converted cars.
NASCAR makes Toyota turn a camry from FWD to RWD and run a copy of the Yates 357 Windsor lol ;)
Been here done most of that......
My old R32 GTR which was raced not just tracked had a terrible issue smashing front diffs off the grid.
I'd get the first race down and the rest of the weekend would be spent with a crownwheel floating around in the front diff.
The car would be very difficult to drive when the front diff would first let go. After some chassis work to make livable I would end up leaving the front diff broken for the rest of the weekends
Nothing else would change just no front diff.
Perfect example of why brad should keep using front diff's :P
white GTR front row of the grid
Obviously not categories for us here, but the ones i was thinking of - GT1, Super GT, JGTC (not sure 33's, but 34's were rwd) DTM, Sport Sedans (i think)
seen that launch allot better, that gtr won powercruise of street drag racing not to long ago, also does mad 4 wheel hellis
I've actually launched that car alot better I'd agree.
As for winning some drag race I doubt it. The car was retired after that race meeting and hasn't turned a wheel since.
Infact I built the car and it never even seen a drag strip during my ownership.
4wd hellis from that car I highly doubt too, it ran a 330 slick front and rear that cost more than most peoples rims and tires put together.
Edited by Risking
Diff explosions were more caused by the transfer case experiments.
We could make a diff survive during qualifying due to the rolling starts, the shock loading put onto the tiny diff from the transfer was doing the damage. The failures were almost always stripped crown wheel teeth.
It didn't matter if the car had small AO48's or dunlop's michellins etc you had to slowly feed the power to the front from a standing start.
Factory transfer case problem fixed but car slower.....
It seems that a GTR in rwd form, purpose built that way would more then likely be better then a straight gtst. Purely due to the car having a better all round setup from factory. Slightly wider track, provision to run bigger wheels/tires which is quite important. This is severely limiting in a gtst. The most obvious one being the stance of the gtr makes it looks a hell of alot tougher then a gtst!
But in the end, if you have enough money you can make any car quick or quicker then your competitors, then you just need the skill to drive it. So eitherway is achieveable, Comes down more so to whats going to give more benefits for the least amount spent on it.
That is what I am thinking Mike.
It is a lot of weight and cost (from an initial stand point and also ongoing maintenance) to remove the front diff and transfer case and all associated components. Will make the dry sump pan easy too.
Also, instead of spending $10k on a PPG dog box you could spend a touch more and get yourself a refreshed used Holinger.
You know "guys like us" dont have enough money to make any car quicker than competitors :)
you would have to weigh up...whether it is worth buying a GTR for over 20k prob 25k then spending all the coin working on it to be rwd.
or buy a 33 gtst for 4k, with a cage say 7k, GTR front guards for a few hundred, fiberglass rear guards, chuck a RB25/30 in it + your hollinger
and you have a car that will be so close to what you want to do you would have to be Michael Shumacher to tell the difference is chassis rigidity
and it wouldnt cost much more than buying a Standard 33 R to begin with. then spend the 20k saved on not buying a GTR on some of Brads trick suspension bits and a dry sump setup.
its what I would do given the coin
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
