Hey guys moving house so gotta get to work on cleaning out my garage. Everything is located in rosanna Vic
R32 rolling shell- no engine or box, undercoated and Gtr bonnet, boot and wing--$2000
Rb25de intake manifold- including fuel rails
and all wiring and hoses--$200
R33 Gtr fuel pump--$200
Blitz intercooler- in okay condition just a few bent fins--$200
Greedy e-manage blue- $200
Hks pod filter $100
S13 stock front bar in good condition--$150
S13 mud flaps--$50
S13 ca18 turbo manifold- $100
0421886425
Cheers., Ryan
https://www.sau.com.au/forums/topic/382710-garage-cleanout/
I've only ever had it as a shell but the guy who owned the car before me had it registered on his L's . So I'll say yes. For pics just go to eBay and search 'r32 shell' mines the one undercOated with a grey bonnet. Thanks mate
https://www.sau.com.au/forums/topic/382710-garage-cleanout/#findComment-6104752
  • 1 month later...
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
