Hicas
samlem
 Share
If its a 33 simple job should take 30-60min depending on your hand skills.
Unbolt everything put in the hicas motor redo everything back up and plug in connectors the a wheel alignment then you are done.
There is a how to guide of installing the lock bar in the DIY section so follow that in reverse and you should be fine
 Share
