i have a skyline r33 gts - t. The car was stolen and the compliance plates where pinched. They took all three of them so it has none. Vic roads says i can't get them replaced. . Another issue is that the car has had a new motor put in in it. ( still an RB25det) . So the engine numbers don't match either. This would not be a huge problem however i let the car become unregistered and now i want to re -register it. I notified the police and vic roads when it was stolen i told them the compliance plates where missing. have i got any chance of registering this car . thanks any help would be great.
https://www.sau.com.au/forums/topic/382752-fixing-my-compliance-issues/
I Don't know about vic, but in sa you gotta get an ID check and they check engine number and VIN. if the engine number doesn't match what they have on their system you gotta get a full inspection. You will have to get this anyway since you now no longer have compliance plates. I doubt having the different engine will matter since it is still an rb25. But yeah you will have to get an exemption from having compliance plates.
hope this helps
Dude you have no chance. None.
so you own a car with no id and want to register it?
not to be a downer here but whats to say you didnt buy a car directly from japan and try to dodge compliance.
no id = no rego. make a track car out of it :)
yeah the police might have it on their records that the compliance plates where stolen . they know i did have a white skyline coupe registered. can't they just look it up under my name and see that it is the same car. i'm desperate i know !
Hi.
If the car has previously been registered and regardless of no plates it should still have the vin number stamped into the firewall. If so the registration people have a record of the car.You should be able to sort out registration if this is the case.
That is why you see cars listed as a statutory write off, with not a single scratch... Apart from that, one of the most knowledgeable importers on here has answered, and you appear to know that he is correct.. face the facts, if the car was insured it should have been written off, pay your premium, get your money, and move on
really?????are we aware that if a vehicle is registered in someones name then it gets re-registered without a vic roads sighting??????just rwc and paperwork as they have you on file as the previuos owner.....there is no one that knows everything.....i just done mine with no sighting...... after 6 years i might add
  • 4 weeks later...
I've just been through the exact same thing in Sa, I was able to get the car re registered with an exemption of compliance plate form from transport SA.
I was issued with a brand new vin number attached to a police report if I have any problems. I did have to fight very hard to get this and the compliance plates where removed by police SA becauses they thought it was a stolen vehicle.
So in SA it is possible, just by filling in a form and going from there.
Iron Chef, is it due to the engine swap that he has no chance? I would find it hard to believe that any car that has the compliance plates stolen, simply becomes a write off.
Would he be able to get the car checked by an engineer, signed off and then given new vin/chassis numbers etc? How do people build up hot rods from a mixture of parts and get them registered?
Australian laws are messed up even more than I thought if there really is no way to get this car back on the road, even if it costs an arm and a leg.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
