well on that note the video I posted was 100% talent with 0% production
The thing that was revolutionary about Climb Dance was not the driving at all. It was more that on board cameras were somewhat unheard of in the day, that is what is great about the video. Plenty of people were racing up the then gravel mountain.
But knowing that someone went to alot of trouble to capture all that footage, in decent quality was a big deal for its time, there is alot more than 20% production involved in the making of it..there was hours and probably months of planning setting up expensive onboard and roadside camera setups etc to show people what a run up the Peak was really like..
These days anyone can produce a short film of equal or even better quality..
You can simply cable tie your phone to the car and video edit random roadside utube clips for a better result than Climb Dance ever achieved..
Oh come on!
When Ari is driving up the mountain into direct sunlight, steering with one hand and blocking the sunlight from his eyes with the other hand? Now that is 100% driving!
it is 100% driving for sure, i dont know why people think I am knocking the driving..its brilliant thats why I posted the clip I posted originally....
As for climb dance well yes its great but, there is also other guys doing the same thing that never made it to video cause it wasnt as readily available in the day
My only arguement was that there was alot of production involved in the making the video...
Someone made the arguement that Ken Block vids are all about production, but comeon he can drive bloody good...
Brings back the memory of driving the Pikes Peak road in 1991 - 1992. It is / was a toll road and my memory says that it was all dirt then. I do not recall the guard rails which you see infrequently in the video. At the 4.48 minute mark is a building which in 1991 - 1992, you made a compulsory stop on the way down for your brakes to be checked. There are great views throughout the journey.
Awesome run, from black top to dirt then back again, the road conditions and traction levels changed about 300 times, with rock wall on one side and cliffs on the other, man, it takes a massive amount of balls and a massive amount of talent.
Thanks for the post, I was on edge the whole time, and in awe.
lol @ the keyboard warriors saying it's boring, slow, could've gone faster etc etc. Get off your high horses and get out on a track, or even better a rally course where one mistake can cost you your life, then you will understand what a truly amazing effort that drive was.
I certainly don't think it's boring, slow etc . the current crop of Pikes Peak drivers are amazing and they are driving awesome machines. My point was just that the 10 min barrier while sounding cool, is not a fair comparison year on year . oh and I have a nostaglia hardon for Group B ...
Any driver that can get up under 12 mins is vey good , under 11 amazing ...
It's in my top 3 events to visit before I die, only a little disapointed that I didn't go before all tarmac.
(really need to be clear when posting... )
    • Yes, well, mine were 31 years old last year when they finally got done. Started to leak a bit.
    • I've ordered a new fuel pump and plan to do all the fuel tank hoses at the same time. Those are the hoses I would rather not go on the road.
    • As a general rule removing rubber fuel hose is so difficult I would replace it if it hasn't been done in the last 5 years. The risk you damage the liner or one of the inner layers is pretty high if it's not almost brand new. BMW's recommendations around coolant hoses is similar. My R33's fuel hoses at the fuel tank were so perished that they were ready to burst FYI.
    • Ah yep, will do. Cheers!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
