Heyya doing lads!
Been on the form for awhile but taut i would share my HCR32 with all you skyline loves.
Scored by Andy @ Powervehicles. One late night i found this HCR32, grade 4 with a C grade on the inside.
Happy to go ahead with placing bid on it i woke up the next morning to find an email saying YES you are the new owner of this.
After a small wait the car was back at andys yard! and on closer inspection it was found to have,
- Tein Super Street
- Bride Drivers seat
- Full exhaust from the Downpipe back
- HKS mushrum filter
Awyway i could fill up pages of the last 2 years but ill fill ya's in on the spec and ill keep you guys updated as it happens
Engine:
- HKS filter
- GTR front mount Intercooler
- GTR fuel Pump
- Full exhaust (Of unknow make)
- Turbo Elbow
- Samco hose's
- HKS Fcon-S
- HKS rad cap
- Nismo thermostat
Suspension:
- CST coilover (replaced the Tein one as they were shot)
- Front and Rear Cuscon strut braces
- Whiteline tension rod bushs
- Apex Front upper camber arms
- DW sub frame collers
- DW poly bush's in controle arms
Wheels
- Rota Torques (sorry lads not that rich) 17 x 9 all around
- 5Zigen Pro-Racer lug nuts
Brakes
- DB-Power Big brake kit 315mm
- Endless Super street
Transmission
- Spec Stage 2 clutch
- Tomei 2way Trax Advance
- Nismo Clutch Pivot
Body:
- Standard Kit with URAS monkey magic bumper
Inside stuff:
- Nardi Deep Corn + Bell short boss
- Greddy SMi Boost gauge + controler
- Fcon Navigator
- Turbo Timer (wow)
Pic's of my motor
The arty ones
https://www.sau.com.au/forums/topic/382771-nissan-r32-rebuild-ireland/
strip down !!!!!!
Head going next week to Martin Tracy @ westward engineering when the rest of the parts arrive. Full Port flowbench, CNC cut valves, new supertech springs and retainers etc!!
Block,Crank,Rods were dropped off earlyer in the week, rebore .5mm over size with forged pistons to match, Arp,-Mains, Rods, and head bolts,
Also dropped off my new injectors to get flow tested !!!!!
Cylinder 1 seams to have been suffering badly from DET
Its only really when ya look at a good(ISH) cylinder ya can see how DET has caused it to eaten into piston number 1
and has left its marked !!
Ill post up what ill be running! I hope to get to 300KW's but not sure what ill get really!
Block back deck and beautifully cross hached
CP pistons in all there glory........:grinno:
smile for ur close up!:boobies:
Full set of new lifters was gona go solid but no point as it ant gona be reving over 8k rpm :( , so got on to the guys at www.apexperformance.co.uk who sorted me out with a set for Very good money!
tho i must say i rang my local nissan garage for the crack to see what kinda money they wanted for a full set!!!! O its a import we'll have to look into it! got a call back !!!!! There 90euro......(tuat for a sec class).......... then they said EACH LOL
As iv said earlyer www.PowerHouseRacing.com came up top guys when a rang looking for valve springs from Supertech, tho these will be helping be got near 8k rpm
Picked up the rad differance to the OEM item!
And the best till last, picked up this PLAZMAMAN inlet with a Plaz throttle body too, must say build qulity is 100% as u can see from the pics below.
Just need to figure out what im gona do with the bottom half of the inlet manifold!!!!!!!!!
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
