Exhaust System For Gt-R
RCCC
 Share
How much is the full system? All the good stuff happens in VIC, I am in NSW :(
I haven't seen a better quality product than the Akrapovic system. If you are in Vic I'd be happy to show mine for sound and fitment.
Yeah I got mine locally for cheaper than I could import one for - good representation in Oz for Akrapovic which is a nice change.
Can check with the Oz agent for the best place locally to get one from.
http://www.evlmotorsports.com.au/
The CF tips are especially sexy if you aren't running decatted set-ups. (The titanium ones are sweet too)
i bought my exhaust direct off alibaba from one of the ti exhaust manufacturers in china
it's 90mm, sounds great with de-catted downpipes and catted midpipe (didnt gain much sound when i added this to my midpipe only though - it's same layout/design as oem afterall), smooth quality welds inside and out, and looks even better
the only thing is i ditched the tips that came with it - i used Garage Active tips instead which i alrready had
Edited by domino_z
I had the Akrapovic evo Titanium exhaust (with carbon fibre tips) fitted to my 2011 R35, supplied and fitted by Tunehouse in Sydney. Tunehouse are a local distributor of these exhausts. ( http://www.tunehouse.com.au/ )
If you want a premium exhaust it is pretty hard to beat. Akrapovic are one of the leading aftermarket exhaust systems makers in the world. http://www.akrapovic.com/car-exhaust/
There is a weight reduction of 17kg with the titanium system..
I had it dyno'd before and after on a Dynapack hub dyno for good benchmarking, on a stock car.
Another reference:
http://www.southernc...ust-p-3272.html
I have no problem believing this system will easily support far higher power levels.
Sound is noticeably deeper and sportier than standard; I think it sounds far louder if you are outside the car than if you are in it. It has more of a "Euro" sound, I think it has a far better sound than the jap exhausts. With the windows up you will hear the exhaust, but I'd rather hear an exhaust than tyre/road noise. This exhaust is a good compromise without upsetting the wife. I have 5 turbo cars with exhausts ranging from stock quiet to very loud, and this one is in the middle with regard to sound db, but I think easily has the best note.
Results:
1. Exhaust benchmark
Red is after exhaust
Green is baseline
Peak power is up from 346 to 370awkw; up 6.9.0%
Peak torque is up from 611 to 629NM; up 2.9%
Torque is up a maximum of about 7% at 3200rpm, but that increase reducing up to 4700rpm, then noticeably increases again above 6000rpm.Power increase was up around 20rwkw, but really only seen over 5500rpm wherethe stock car flattened, but with the exhaust the power kept increasing. Ithink the increase in top end was a good pointer to its capability if pushed further.
If you look at the akrapovic dyno graph at http://www.akrapovic...9/evolution-65/I'd say they are almost spot on, except that I got more top end from 5500 rpm than what they claimed on their dyno graph (they used a 2010 model whereas I have a 2011).
2. 1st very conservative Ecutek tune, no other changes otherthan exhaust.
Then Tunehouse added a very conservative starting Ecutek tune with just 1 pound extra boost (peak boost 15lb compared with 14 stock), resulting power was up around 11% from 2500rpm all the way to 7000rpm. Main difference isfelt from 2500 to 3500rpm, with torque up around 25%, and I believe that has alot to do with bringing boost in earlier, and that is the area where the akrapovic exhaust excels. That makes the car far more flexible and better carto drive, and it pulls far stronger from 2000rpm.
Excellent jump in power and torque everywhere; boost isbrought in earlier.
Compared with original baseline, torque is up 30% at 2500 and up 25% at 3000rpm, so it is far more responsive low down and far more driveable.
Peak power is up from 346 to 384awkw; up 11.0%
Peak torque is up from 611 to 680NM; up 11.3%
3. boost used for that tune :
More boost under 3200rpm, otherwise peak boost up just 1lb ;14lb to 15lb ... bugger all.
So I and tuner (Tunehouse) are very happy with the exhaust choice, and a very good base from which to push higher if required.
It is also of the highest quality.
Brian
Edited by bcl
alibaba is hit or miss......bit like ebay
afaik there are two main ti exhaust manufacturers in china - jiajun and gzy (which is where mine came from)
imo jiajun quality isn't there, just like majority of the carbon parts coming out of china atm - with exception of revozport and top racing which in my experience were even better quality than japan's zele carbon
there are bargains to be had, but keep in mind alot of factories work on minimum order quantities - you may get lucky and they'll sell you a single unit if they have stock
but they wont get the manufacturing team away from making ipads for some aussie guy who wants some ti underbody bling
Edited by domino_z
mmmmm ipad
  • 5 months later...
Another reference:
Results:
Green is baseline
Brian
How much did the exhaust and the tune cost?
 Share
