Hi I’m after some help as my r33 gtst s2 rb25det needs arebuild.
I’m after advice on any good kits to buy and good machine shops to go
to get crank or bore machined. Also what to know what brand of parts are good
to get (pistons, bottom end bearings etc.).
I’m after all the advise I can get please…..
I’m located in Melbourne.
https://www.sau.com.au/forums/topic/382790-rb25-rebuild/
I'd go genuine nissan gasket set/VRS kit, you can get them cheap if you buy from usa same with bearings/rings.
depending on the condition/age of the pistons you may be able to reuse them.
https://www.sau.com.au/forums/topic/382790-rb25-rebuild/#findComment-6106287
Consider buying a short block already completed, you get a warranty and if you buy from a reputable builder you get a guarantee that it is done properly. No risk of someone doing a dodgy job, especially if they have never built an rb before.
rips and redrracing do some fantastic motors all completed ready to go with a warranty.
https://www.sau.com.au/forums/topic/382790-rb25-rebuild/#findComment-6107739
If its affordable I'd base it on a Neo head and matching pistons because I think the later revision has some combustion advantages over the R33 version . I'm not sure what the story is with the CAS here , would the late plastic cover R33 CAS mate the R34 cam drive with R33 engine electrics ?
Also is an RB30 short an option for you ?
A .
https://www.sau.com.au/forums/topic/382790-rb25-rebuild/#findComment-6107846
Rollz thanks for the comment.... Do u have the contact number or websites for those places that you have suggested?
And thanks to everyone with the help still.... But I would still love more help with website and places to buy good qaulity parts for a build plus any advise on a good machine shop to check and measure bore and crank...
https://www.sau.com.au/forums/topic/382790-rb25-rebuild/#findComment-6108087
Depending on the HP you are targetting.
For reference on my test rig rebuild:
Forged Pistons from:
CJ motors 0421622288
Bearings, head bolds and gasket set from:
MD spares: 95530388
You will need strong valve springs for high boost, I'm using supertech valve spring kit from ebay US.
I Used Reflex engineering for engine rebore, short block building and head reconditioning: 93054807
AMR work shop for assembly: 93866196
That would give a fairly solid "stock engine" but nothing crazy.
https://www.sau.com.au/forums/topic/382790-rb25-rebuild/#findComment-6108190
Thanks hypergear for reply.... What area codes are those numbers because I might give them a buzz...
Also with that build what sorta power where u getting???
Thanks alot :)
They all in Melbourne, the area code is 03. The most power I've got of this setup was 345rwkws on 28psi with 98 purple. That was also running stock manifolds and etc. Its used as a test car so it gets flogged on 20psi+ all the time and holding together fine.
https://www.sau.com.au/forums/topic/382790-rb25-rebuild/#findComment-6108680
Its a testing rig so it gets new prototypes installed every week. Its currenly running a Ceramic roller bearing G3 which drives pretty nice, the 345rwkws that was a KAI high flow out of a OP6 rear, which made the power but not so good in driving ability.
Cost in building this motor I've spent just under $4G including labor. If your block isn't bad as mine (I had sleeve in 1 cyc) and not looking to beef up its valve springs then you can get every thing done for about $3G.
https://www.sau.com.au/forums/topic/382790-rb25-rebuild/#findComment-6108775
http://www.ripsltd.com/index2.html
paul diemar from red r racing is the other bloke, do a google or search on here, you will find something.
Do it once do it properly imo, the amount of dodgy stories I hear is ridiculous, a lot of people end up doing it twice so you'd be better off just spending the extra the first go and having it done properly. There are lots of other workshops that would do it but being as you are in the USA these are the only two that I know regularly ship overseas. Shipping time will be a while, but I doubt it would be much longer than paying someone to build a motor for you.
A .
Need to use the R34 CAS with R34 head, but you just rewire the pins 1-4 2-3 3-2 4-1 and it works fine, same deal with the different coils, you just cut the ignitor out of the loom and it runs fine.
Edited by Rolls
https://www.sau.com.au/forums/topic/382790-rb25-rebuild/#findComment-6109106
Was the machining expensive?
What about ur crank? Did u keep stock rb25det crank? If so did u have to get it machined?
Thanks alot with ur replays hypergear :)
I had one badly damaged bore, which had to be sleeved. other wise its only $40 per bore, the crank wasn't bad so they just linished it and assembled every thing together. If your engine's not bad with you doing most of the work the machine part is pretty cheap. Ring up reflex and get a quote. tell them you are from blah blah workshop and they give you a trade discount. How ever bring them the engine block and pistons that are ready to be machined and fitted, they charge alot for stripping the engine.
https://www.sau.com.au/forums/topic/382790-rb25-rebuild/#findComment-6109197
    • Welcome back, glad to hear life's wheel is turning in the right direction
    • Awesome pics Rezz, thanks for sharing them Another stop for my "need to do in Japan" list
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
