Up for sale is my Nissan Skyline 1993 R32 GTS.
This is one of, if not the only 5 Speed Non turbo R32 coupes for sale on the internet!
P-Plate legal
- Factory non turbo
- Factory manual
- Gun metal grey
- Rear wheel drive
Exterior
- Bunnings 'garden edging' front lip
- 6000k HID's low beam
- 6000k HID's fog lights
- White LED parkers
All stock body parts
Interior
- Momo gear knob
- Kenwood MP3, USB, AUX head unit
- Kenwood 4-channel 200 watt amp
- Us-Audio 12" subwoofer power by the amp
Engine
- Standard internal RB20DE
- Custom CAI to stock air box
- 52mm ASI aluminium radiator
- 2.25" cat back exhaust to rear muffler, will also include 4" cannon
Suspension and Wheels
- BC BR coilovers
- Stock wheels
- Random black 17" wheels with tread
- Got the alternator belt, fan belt and power steering belt all replaced a couple weeks ago.
- Serviced every 5000k's
- Always filled up with 98 at a BP or Shell
- Whole new cooling system installed (aluminium radiator, hoses, thermostat, coolant) 10,000k's ago
I have owned this car for a bit over a year now and have used it as my daily driver. I'm selling due to wanting an upgrade of something different.
Rego ends January 2012
The car is screaming out to be resprayed, I purchased it with the clear coat flaking and some minor dings. Since owning it, it now has a dint on the bonnet and a scratch on the rear drivers side quarter panel.
Bought it completely stock with the exception of a pod filter. While owning it a respray was the first thing on the list but got I carried away buying wheels, coilovers and other stuff mentioned above :rolleyes:.
The power steering pump only half works so the steering is heavier than usual.
Contact me on 0401286190. Private numbers will not be answered.
PRICE: 6,000 WITH REG TILL JANUARY 2012, ROADWORTHY CAN BE ORGANISED
Edited by arthur32
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
