The time has come to part with my amazing AE86.I have found another car I want so this must go :( I know i will regret selling this but its time for a change.
2011-07-30131503.jpg<
1983 AE86 ADM with all JDM running gear.
The car has been mainly built to be a Bathurst replica in keeping with the 1986 TTA regulations.
Bigport 16v 4AGE currently has ONLY approx 12,000kms
Chassis has approx 240,000kms but has been reconditioned from the ground up.
Jap spec Disc to Disc t Series diff with 4.77 ratio and 2 way Cusco center.
Simmons V4 Front 15X7.5 and Rear 15X8.5 (unsure of offset - they sit flush)
5spd manual (fresh box new clutch new lightened flywheel etc.)
Wilwood T3 Brake kit (new) (uninstalled)
280 degree cams (new) (uninstalled)
BC height and damper adj. coilovers (new)
Whiteline swaybars (new)
3months rego just put on
Shannons have valued the car at $18,500
my asking price has dropped to $13,500
if it doesn't sell it is only going to go up in value so it doesn't bother me :)
never taken to the track just driven on the weekends weather permitting
Non smoker
washed weekly
car speaks for itself.
Call me on 0411 768 931 Cheers Sam ---- Located near Mitcham SA
61182_432902298612_649478612_5174659_1948766_n.jpg 63830_432902323612_649478612_5174660_4947038_n.jpg 65336_437779093612_649478612_5272396_4740519_n.jpg33724_438219078612_649478612_5279188_8162781_n.jpg64349_438219168612_649478612_5279193_2154220_n.jpg40118_438323218612_649478612_5280766_5952344_n.jpg37121_438323238612_649478612_5280767_5676774_n.jpg64645_438324898612_649478612_5280806_47147_n.jpg76624_455310668612_649478612_5555302_4889155_n.jpg59674_438861868612_649478612_5289387_6767052_n.jpg47066_438861888612_649478612_5289389_7591555_n.jpg66479_438861838612_649478612_5289386_2094594_n.jpg44266_438861908612_649478612_5289390_5574018_n.jpg33563_438861948612_649478612_5289393_2502216_n.jpg67393_438861958612_649478612_5289394_1259302_n.jpg67540_440509688612_649478612_5324149_3814120_n.jpg2011-08-26163727.jpg73850_459229348612_649478612_5601013_7882391_n.jpg2011-09-16181121.jpg
Please someone take it to a good home!
Edited by APE
not hard to do a front conversion...
it also has a deep dish leather stering wheel (new)
Dolby Cd player (can play dvds)
and oil pressure guage
Edited by APE
  • 2 months later...
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
