Now i have heard a few different stories from people regarding coilovers for c210's ..
Some people say that R33 coilovers fit right upto the rear of the c210, while some people say that s13 gear fits but you need to drill 2 holes to fit them up.
As for the front, People are saying i can use R31 struts that bolt straight up and also giving me the option for a bigger brake option later on, then some people say that mr30 gear fits up and you can get custom coilovers for mr30 and they will fit to c210 strut tops.
Can people please clear this up for ?
https://www.sau.com.au/forums/topic/382820-c210-coil-overs/
ive heard the same in regards to the s13 coilovers :yes:
, but the 33 not too sure....:/
pedders suspention do a kit for custom coil over kit :merli:
(ive priced them up 4 my car (c210)) approx 800 bucks if i pulled the struts out. :thumbsup:
https://www.sau.com.au/forums/topic/382820-c210-coil-overs/#findComment-6106846
if u wanted to go cheap in the front ive put XF front springs in the front of my old c210 (i did cut them so it wouldnt sit real high :domokun: ) and they were stiff as hell and worked well
https://www.sau.com.au/forums/topic/382820-c210-coil-overs/#findComment-6106850
WOW $800 is pretty good. considiring how much you pay for parts for the car lol. So i take out all my struts and that and take them to pedders and they make me custom coilovers ?
they still use ur struts but cut the botton spring support (not sure of the technical word lol) and weld on threaded sleaves and install new spings with the lock nuts.
I have seen pics and they look great, best of luck keep me posted
https://www.sau.com.au/forums/topic/382820-c210-coil-overs/#findComment-6106953
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
